It is currently Thu Oct 19, 2017 8:53 am Advanced search
"Sandy" looking beads
Postby jroark » Thu Aug 10, 2017 6:15 pm
I had one of you guys comment on another thread that I must be using 4043 filler because of the sandy looking beads. I guess that's normal? How do you guys get shiny beads using 4043? The welds I'm doing look fine but I was wondering about that certain thing and after the other post I couldn't figure out if I was doing something wrong or if that's just the way it is. Thank.
jroark
Re: "Sandy" looking beads
Postby Poland308 » Thu Aug 10, 2017 6:43 pm
Just the way it is. It has to do with the individual components of the filler. As well as the metal your welding on. It's not so much that you won't ever get shiny beads with it , but that it's common and not bad if you get that grainy look. Super clean metal and filler will help a lot.
Postby LtBadd » Thu Aug 10, 2017 7:01 pm
To demonstrate how dirty a new length of aluminum filler is
Take a paper towel and isopropyl alcohol, wet the towel and wipe the filler...see the black line that just came off the "clean" filler? Keep wiping it down until you don't get any more dirt.
How will this affect the weld, for most jobs not at all, if you were doing critical work then it would be worth the effort.
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby jroark » Thu Aug 10, 2017 7:56 pm
Ok thanks. I've cleaned the filler with acetone but really got nothing different. The beads look shiny under the hood but after they cool they're back grainy looking. At least it's normal.
jroark
Postby pgk » Fri Aug 11, 2017 2:56 pm
Try some 5356 ;)
Esab SVI 300, Mig 4HD wire feeder, 30A spool gun, Miller Passport, Dynasty 300 DX, Coolmate 4, Spectrum 2050, C&K Cold Wire feeder WF-3, Black Gold Tungsten Sharperner, Ellis 1600
pgk
Postby motox » Fri Aug 11, 2017 5:54 pm
try clean 4943 wets out nice.
motox
Postby MosquitoMoto » Mon Aug 14, 2017 8:17 am
I've tried 4043 of all sizes and brands.
Cleaned the filler, cleaned the work, ran cold, ran hot, varied balance, hz, gas, tried whistling, tried humming, stuck my tongue out the corner of my mouth...the bead is always sandy.
I use 5356 now. ;)
K
MosquitoMoto
Postby GreinTime » Mon Aug 14, 2017 9:55 am
Just don't use AlcoTec
Postby motox » Mon Aug 14, 2017 7:16 pm
Unread postby GreinTime » Mon Aug 14, 2017 9:55 am
yup it sucks
motox
Postby jroark » Tue Aug 15, 2017 9:42 am
Does 5356 weld different than 4043 much?
jroark
Next
