Page 1 of 2
Re: "Sandy" looking beads
Posted: Wed Aug 16, 2017 11:05 pm
by Mattwho777
How's the grain of your tungsten? Is the arc wandering any?
Sent from my MotoG3 using Tapatalk
Posted: Wed Aug 16, 2017 11:46 pm
by Onenastycummins
Mattwho777 wrote:How's the grain of your tungsten? Is the arc wandering any?
I grind tungsten horizontal, not how they recommend but I've bet ever had an issue. I'm not getting any arc wander
Posted: Thu Aug 17, 2017 12:15 am
by 5th Street Fab
You could light up on some stainless real quick and keep the gas over it til it's completely cool and if it's not silver then it's definitely a gas problem
Posted: Thu Aug 17, 2017 12:52 am
by Onenastycummins
i actually weld quite a bit of stainless with no issue what exactly does this test you speak of show me ? I thought stainless typically turned colors
Posted: Thu Aug 17, 2017 1:21 am
by 5th Street Fab
It does typically turn colors but if it's kept in gas coverage until it's cool enough to touch it should be silver. All you need to do is get a puddle started then stop and keep the torch over it with the gas flowing and check the color.
Re:
Posted: Thu Aug 17, 2017 5:53 pm
by Mattwho777
Try grinding it the other way and just see if it helps or not.
Aluminum is very sensitive. Hope you can get it figured out.
Posted: Sun Aug 20, 2017 5:39 pm
by Onenastycummins
ill give the drill and my belt sander trick a shot and see if it makes a difference . I haven't had much time this week to mess with anything in the garage
Posted: Sun Aug 20, 2017 6:14 pm
by Mattwho777
I know what you mean. Too much to do. Not enough time in a day.
