It is currently Thu Oct 19, 2017 8:53 am Advanced search
arc help for a newbie
Postby Ratsathome » Sat Aug 12, 2017 8:39 am
Hi guys/girls
Haven't been on here for a while.
I bought a combination welder last year and have been using the "mig" and "mma" a lot.
Bought argon gas and set up the Tig today to teach myself Tig.
Cleaned the metal as best as I can and even wiped it down.
When I initiate the arc (HF) there are barely any arc. If I keep the "small" arc going for 15 - 20 sec the metal does not even warm up with the small arc.
Welder: http://www.expondo.co.uk/stamos-power-2-combined-welder-tig-220-a-mig-220-a-e-hand-2131-?c=417
Torch: WP-26
Tungsten: 2% Lanthanated grind to a needle point
2mm steel(5/64)
V: 18-24 (tried all in between)
A: 90-219 (tried all in between)
Argon: 5 L/M (11cfh)
If need be I can video the arc initiation for a better understanding.
Please any help would be appreciated.
Ratsathome
Re: arc help for a newbie
Postby dgapilot » Sat Aug 12, 2017 8:46 am
Do you have a foot pedal, or just a torch switch? How are you grinding your tungsten? Are you sure you have a good ground?
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
dgapilot
Postby Ratsathome » Sat Aug 12, 2017 8:50 am
dgapilot wrote:Do you have a foot pedal, or just a torch switch? How are you grinding your tungsten? Are you sure you have a good ground?
Switch on the torch. I used a new grinding wheel on my grinder.Even tried the arc directly on the ground clamp with the same results.
Ratsathome
Postby Ratsathome » Sat Aug 12, 2017 12:11 pm
Got sorted :oops: Had the Earth in the wrong socket on the machine :D
Ratsathome
Postby AndersK » Sat Aug 12, 2017 1:32 pm
So you mean you ran EP? That usually gives quite an aggressive Arc :mrgreen:
AndersK
