Page 1 of 2
Re: Grinding tungsten tip from a newbie
Posted: Wed Sep 06, 2017 7:31 pm
I use 1/8 and 3/32 99% of the time. I've only recently begun to experiment with smaller sizes.
Posted: Thu Sep 07, 2017 9:21 pm
by Graveyard
LtBadd wrote:Graveyard wrote:LtBadd wrote:Thanks for the review, have you had to replace the wheel yet?
No sir, still using the same wheel and I'm told that when one side wears out you can flip it. Not sure if there is any truth to that but I'm going to try when the time comesz
What diameter tungsten do you typically use? I use mostly 3/32 and 1/16"
I use 3/32 (red) 99% of the time.
Posted: Mon Sep 11, 2017 6:58 am
by Futterama
So I've been in contact with CK and this is their response to the discolored tungstens:
I looked at our stock of T0207GL and there is some discoloration on the electrodes. I did some digging and it is actually an oxide layer. The surface oxide layer can be more aggressive in hot humid weather. I think you guys have been experiencing that this year. If you take a clean emery cloth and run it up and down the electrode, it will clean it up and be back to shiny silver. The small diameter, .020” (.5mm), would be more susceptible to having a more visible oxide layer than a bigger diameter. I am sure that even the first striking of an arc would burn it off. I don’t see this as being anything to worry about but just to cross your t’s and dot your I’s put an emery cloth on it and remover the oxide layer before you weld.
Posted: Mon Sep 11, 2017 10:17 am
by AndersK
....hot humid weather. I think you guys have been experiencing that this year.
Coldest summer in a hundred years in Scandinavia this year it was.
Posted: Mon Sep 11, 2017 2:48 pm
by Futterama
I just received my diamond grinding discs from ebay today:
http://www.ebay.com/itm/6-Grit-60-to-30 ... 2749.l2649
http://www.ebay.com/itm/4-80-3000-Diamo ... 2749.l2649
These work fantastic, much better than sandpaper!
Now, I learned that sandpaper is not the best for metal grinding, so I got some emery cloth to try out too, and I'll compare to the diamond discs.
The diamond discs are 120 grit and 320 grit. After grinding using the 320 grit, the tungstens look like on the photos. The first photo is a 2mm - 5/64" tungsten, and the second photo is a 0.5mm - .020" tungsten.
Do they look like they should or do I need to get a finer grit diamond disc for the final grind?
- 1314962819388.jpg (28.06 KiB) Viewed 2218 times
- 1314962761451.jpg (23.47 KiB) Viewed 2218 times
Posted: Mon Sep 11, 2017 2:49 pm
by Futterama
2mm tungsten final grind with 400 grit emery cloth.
Posted: Mon Sep 11, 2017 3:01 pm
by Futterama
2mm tungsten final grind with 1000 grit emery cloth.
What's good enough for hobby work?
Posted: Mon Sep 11, 2017 10:41 pm
lol that's plenty good. At work or in the field sometimes the only thing handy to clean up a tungsten is a 4-1/2 inch grinder with a hard wheel. Those are so rough you can see the grooves at arms length. But they weld!
