stefuel
    Sat May 27, 2017 6:26 am
On vacation. Never done this before but might be required to do it soon so off to the scrap pile for something to do a test joint with. The specification calls for a 60 degree bevel, a sleeve and one material thickness gap. Haven't done any aluminum for over a year so this will be interesting. Wish I had a smaller torch. I only have a 250 amp water cooled one at home and it's cumbersome. Pictures to follow, unless I really suck today :lol:
stefuel
No pictures yet. First attempt sucked. On the outside, the weld looks OK but I'm not penetrating into the sleeve. First problem was my gap was to tight. It's a tight 1/8th when it should have been closer to 3/16ths. My bevel is about 45 degrees. I forgot to mention that the spec also calls for pulse mig. I thought tig would be a stronger and cleaner weld. I did try a sharper point on the tungsten and higher frequency to try and focus more on the sleeve. It takes quite a bit of time to prep a sleeved joint so I'll try again tomorrow or Friday.
stefuel
Not a complete hack
stefuel
Started with this but tapped it together to close and it wouldn't pull apart so my gap was to narrow
