It is currently Thu Feb 22, 2018 6:43 am Advanced search
Tig welding aluminum with a high freq box no pedal
Postby Jalmon18 » Mon Sep 11, 2017 7:51 pm
I use a high frequency box with an ac dc stick generator and stick welder at work and in the feild all the time for tig welding aluminum.. nvr use a pedal I was wondering your take on this I have great results as long as I has a copper spoon to run off on but I can't seem to find anyone else that does this regularly can't find any videos either.. is it really that rare?
Jalmon18
Re: Tig welding aluminum with a high freq box no pedal
Postby MinnesotaDave » Tue Sep 12, 2017 3:09 pm
In my opinion it's not really common except in the field.
I've done it down to 1/16" material and it's not terribly fun with the thin stuff.
1/8" and up it's not too bad - but I really like my foot control and use it almost exclusively now :D
I still have a high freq box but have not turned it on in a long time. Only kept it around for my engine drive.
Airco 300 - Syncro 350
MinnesotaDave
Postby cj737 » Tue Sep 12, 2017 5:10 pm
I use Lift Arc and static amps when tacking large projects. If I were a better welder, heck, I'd probably throw my damn pedal away except for when I'm sitting at my table welding small stuff :oops:
Postby MinnesotaDave » Tue Sep 12, 2017 7:40 pm
cj737 wrote:I use Lift Arc and static amps when tacking large projects. If I were a better welder, heck, I'd probably throw my damn pedal away except for when I'm sitting at my table welding small stuff :oops:
Lift arc on aluminum?
MinnesotaDave
Postby cj737 » Tue Sep 12, 2017 10:40 pm
Yes. Perhaps I stuttered when I typed it?
Postby MinnesotaDave » Wed Sep 13, 2017 7:08 am
I just haven't seen an AC lift arc machine - only DC.
No, you didn't stutter. But you also didn't specify, so I asked.
MinnesotaDave
Postby Poland308 » Wed Sep 13, 2017 7:07 pm
You can run that way with my thermal arc 186 if you so choose.
Postby MinnesotaDave » Thu Sep 14, 2017 7:56 pm
Poland308 wrote:You can run that way with my thermal arc 186 if you so choose.
That's pretty cool, I haven't used one yet that did that.
Only would have worked with a torch switch.
MinnesotaDave
Postby Poland308 » Thu Sep 14, 2017 8:23 pm
I prefer the torch switch as well. But I had my scratch start rig already set up and didn't want to switch out torches, had just a little spot that needed about 2 inches of weld and made it work good enough. Think I would need more practice if I was going to do something more important. Over all it's not that much different than running straight amps with the button.
Postby croshaul » Mon Sep 18, 2017 9:47 pm
I have a Hi-Freq box that was the only way to weld aluminum 40 years ago. It has the torch trigger.It is a rough machine but it does the job just not with much finesse.I have since picked up an HTP 221 Invertig that leaves the box on the shelf.
croshaul
