Lightning
    Wed Aug 24, 2016 9:55 pm
Why would you want to do this? It just seems like an odd question, like "Can I run my car engine without oil, just to run to the store?"
zamanali
    Thu Oct 05, 2017 12:08 pm
I watched the Jody video regarding speed tacking with a blast of amps for thin metals, and was curios about how much argon gas is really working and affecting during that fraction of a second.
Originally the question without Argon gas was only for "Tacking" and not for a complete continuous weld.
I do understand welding with TIG without argon gas is a No-No, but that "speed tacking" by Jody is not in any welding Textbook but working marvelously.
It made me wonder during that "speed tack", does it provide enough time for things to get messed up real bad? or will it be just fine? or maybe it could be some sort of acceptable? those are still untested and unseen ?
    Sun Oct 27, 2013 10:57 pm
zamanali wrote:I watched the Jody video regarding speed tacking with a blast of amps for thin metals, and was curios about how much argon gas is really working and affecting during that fraction of a second.
Go ahead and see if everyone is somehow wrong and that tacking is just fine as long as it's quick.
I seriously doubt you will like the outcome, but from what I've read it seems you keep asking the same question - fire it up and try it and let us know - lol :D
Btw, speed tacking is not against textbooks. It's just tacking with more amps in less time - some very small parts are actually spot welded this way.
zamanali
here, i couldn't test it myself for some reason
i was hoping to see if anyone tested it out before, at least i learnt from others experience, if not from the exact test
about the spot weld you mentioned, i suppose those are without any shielding gas, isn't it ?
Most spot welds are done with copper contacts that have to be replaced often due to the pitting from the process. That’s like comparing apples and oranges.
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
The effect of gas is immediate. Running anything without gas that should have gas causes immediate porosity. A fraction of pre-flow/post flow secures the tack from outside contaminants in the air.
Lightning
When you TIG weld, in addition to providing a shield of inert gas, the argon or helium ionizes into plasma, providing a conductive path for the current to flow from the tungsten to the work.
Air ... not so much. Plus there's all that oxygen (21%), just itching to react and combine with molten metals! BOOM
Hint: Without INERT GAS, you don't have Tungsten INERT GAS (TIG) welding.
...and if you watch, when Jody (or anyone competent) who does speed tack, hovers momentarily over the tack to allow the shielding gas to cool the tack and tungsten. Most machines have some amount of post flow or user set post flow to cool the tungsten and protect the weld.
Poland308 wrote:Most spot welds are done with copper contacts that have to be replaced often due to the pitting from the process. That’s like comparing apples and oranges.
I was actually only referring to the tig spot weld. Basically just speed tacks and sometimes done with a spot timer for consistency.
Well there’s that too.
