It is currently Fri Jan 19, 2018 9:20 am Advanced search
Chinese 240V TIG welders
Postby kiwi2wheels » Mon Oct 09, 2017 4:44 pm
A question for our Australian members. A friend in QL is considering one of these two machines. Application would be for motorcycle parts and repairs. The idea is to eventually set it up with a cooler unit and a 20 series torch.
https://www.tradetools.com/product-rang ... duty-cycle
https://www.ewelders.com.au/welding-mac ... erter.html
We've browsed the internet to see if these are a "known" Chinese brand, but no results. If anyone has used one, knows someone who has one or can add some comments regarding these machines , it would be appreciated. Thanks.
kiwi2wheels
Re: Chinese 240V TIG welders
Postby MarkL » Mon Oct 09, 2017 8:00 pm
Here's a thread on the Renegade.
Uni Mig has a 20% duty cycle at 185A, not sure what you plan to do with it, but that's pretty low. Couldn't find any specs on Renegade.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
MarkL
Postby MinnesotaDave » Mon Oct 09, 2017 8:53 pm
JASIC welders should be available near you right?
They have a good reputation. I don't own one, but people I trust own them and sell them.
Edit: I forgot uni-mig is made by JASIC....
Airco 300 - Syncro 350
MinnesotaDave
Postby bigblock57 » Mon Oct 09, 2017 10:18 pm
I have the uni mig 200 amp ac/dc tig and find it good for home use
I don't use it all day every day but for my situation I am happy with it
bigblock
bigblock57
Postby MosquitoMoto » Wed Oct 11, 2017 7:19 am
Hiya Kiwi.
I've been using the Metalmaster 215 Elite from Tokentools for a couple years now. Can't fault the machine or the seller - always ready with backup regardless of when I call.
I've welded thin steel tube, thick plate (when making a bender) as well as thin aluminium, stainless...all sorts. I've had very good success repairing aluminium and cast aluminium motorcycle parts - rearsets, broken cast aluminium frame lugs and even cast aluminium subframes.
The 'Tig for dummies' is great to get started but I quickly jumped in and started experimenting with frequency settings, pulse, everything. Has been an easy machine to learn on and I don't feel I'll outgrow it any time soon.
One tiny note - the standard size 26 torch supplied with the unit is too big and clumsy - request a 17 and you'll be good to go. Hope this helps.
Moz
MosquitoMoto
Postby kiwi2wheels » Wed Oct 11, 2017 10:24 am
Many thanks to all who have provided information and opinions.
Makes for a much more informed choice. Cheers.
kiwi
kiwi2wheels
