It is currently Sat Jan 20, 2018 7:03 am Advanced search
best budget AC/DC tig machine
Postby typ122 » Thu Dec 07, 2017 11:17 am
Hey guys I'm new to the forum. I have some experience tig welding with my old job but I would like to get a welding machine for my home shop. I was using a miller 210 at my old job. I don't usually weld anything crazy thick but would like to do at least 1/4". Thanks for you input.
typ122
Re: best budget AC/DC tig machine
Postby Farmwelding » Thu Dec 07, 2017 4:10 pm
typ122 wrote:Hey guys I'm new to the forum. I have some experience tig welding with my old job but I would like to get a welding machine for my home shop. I was using a miller 210 at my old job. I don't usually weld anything crazy thick but would like to do at least 1/4". Thanks for you input.
Any idea how much you are willing to spend and what type of projects you might plan on doing?
Postby typ122 » Thu Dec 07, 2017 6:59 pm
ill be welding axle housings for race cars,brackets and other things of that nature. Aluminum stuff, oil pan repairs.
typ122
Postby LtBadd » Thu Dec 07, 2017 8:51 pm
I'll assume your budget is $2k or less for a AC/DC Tig unit and you're located in the US
Some options are
Miller Diversion
Lincoln Square Wave tig 200
Everlast, you'll find some love them, some hate them.
AHP makes a unit for around $1k, never used one but have read good things. Foot pedal is very basic
Like most budget machines, you may not (will not) be satisfied with everything, such as the foot pedal or TIG torch, therefore you should have extra $$ set aside should you want to upgrade
The Lincoln may be the best, depending...
1/4" aluminum is the top end (or close to it) for these units
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby Poland308 » Thu Dec 07, 2017 10:26 pm
I would add the Esab 186i. I have the thermal arc version and have been happy so far. Also less than $2k.
Postby Farmwelding » Thu Dec 07, 2017 10:59 pm
LtBadd wrote:I'll assume your budget is $2k or less for a AC/DC Tig unit and you're located in the US
Some options are
Miller Diversion
I've used both the diversion and squarewave. If it comes to those two, squarewave all the way. Added features for aluminum and stick welding in case you need it and it is still cheaper than the diversion.
Postby Bradk » Fri Dec 08, 2017 8:23 am
typ 122,
Don't forget the CK Worldwide MT-200 ac/dc Tig, it is pricier at $2155 but is supposed to be an excellent machine. Check out reviews and videos on the unit. Price given is at Arczone where I buy a lot of stuff online. I have a Lincoln SquareWave Tig 200 and really enjoy the machine but changed my torch to a TEC Welding Products sz 17 torch as I wanted a shorter torch body than the Lincoln sz 17 which is ok, just personal choice. I also own a Everlast PowerTig 250EX with an Everlast water cooler as well, whole different league then the air cooled torch (no hot torch to fry my fingers). I sometimes am using the air cooled torch on my Lincoln and end up roasting my index finger from holding a bead too long, just a dumb ass I guess? Ouch!
Brad
Bradk
Postby LtBadd » Fri Dec 08, 2017 11:38 am
Bradk wrote:typ 122,
Brad
Wow that's quite a bit more then the Lincoln, it better shine for that cost. Have never seen any reviews for that unit, but then I haven't went looking.
Right now you can but the SW TIG 200 and get a $125 rebate as well. Plenty of good reviews of this machine out there
LtBadd
Postby Oscar » Fri Dec 08, 2017 12:30 pm
The AHP still seems to be the best bang-for-the-buck, IMO. Just rig up something for the footpedal, and you're golden.
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Postby sedanman » Fri Dec 08, 2017 6:31 pm
Brad
The CK Worldwide machine is a Razorweld 200 acdc in a different case. The Razorweld can be had for $1,700 and is awesome at that price point.
sedanman
Next
