Airco 300 amp tig
Posted: Fri Dec 08, 2017 11:32 am
Hi all new here and have a question on this 300 amp tig made for airco,by LTEC its one of the red orange ones.
I got it up and running at my house on a 50 amp breaker with a run of 2.5 feet of 8 gauge wire.
My friend who does electrical with me at the school district said if i run it on this size breaker and wire it will cut my power in half,NOW what i want to do with the welder,which is 1 phase 220.
I want to start building tubular control arm,the material will be 1.5x.156 wall dom steel tube to ball joint cups that have a wall thickness fo .250 to .437
Will i have enough power to get good penetration,or do i need to up grade to a better power source?
Thank you.
Phil
Thank you.
Phil
