It is currently Mon Feb 19, 2018 12:07 pm Advanced search
Tig brazing aluminum
Postby adksigns » Mon Feb 05, 2018 9:26 am
Can aluminum be brazed, using a tig machine?
Matt
adksigns
Re: Tig brazing aluminum
Postby cj737 » Mon Feb 05, 2018 10:10 am
Yes, but why would you? It will be less strong than welding it...
Postby adksigns » Mon Feb 05, 2018 10:51 am
cj, I am welding small aluminum tubing 3/16 and being a beginner to aluminum I am having some trouble blowing out the weld joints. I thought if I could braze them I would need less heat but still be strong enough for its intended purpose.
adksigns
Postby Farmwelding » Mon Feb 05, 2018 11:12 am
adksigns wrote:cj, I am welding small aluminum tubing 3/16 and being a beginner to aluminum I am having some trouble blowing out the weld joints. I thought if I could braze them I would need less heat but still be strong enough for its intended purpose.
You are blowing through 3/16" thick tubing?
Postby adksigns » Mon Feb 05, 2018 11:14 am
3/16 6061 .035 wall thickness
adksigns
Postby cj737 » Mon Feb 05, 2018 11:18 am
Probably its 3/16" OD and 0.030 wall.
Something to try: preheat your tubing with propane. If your machine allows a change in Freq, dial it up to 150Hz or higher. Set your AC balance down to 65%. This will help reduce your heat effect and penetration a bit. And once your puddle starts, get off the PEDAL. Or, Bump along on/off the pedal making basically tacks of 2-3 dips. Then stop. Let cool a bit, then begin again. Thin aluminum is the Devil's Toy to weld for new welders. :twisted: :evil:
Postby adksigns » Mon Feb 05, 2018 12:43 pm
Thanks for the help I have a AHP AlphaTIG 200X 2016 version. To get back to my first question is it possible to tig braze aluminum?
Thank you, everyone, for your help.
adksigns
Postby cj737 » Mon Feb 05, 2018 1:14 pm
adksigns wrote:Thanks for the help I have a AHP AlphaTIG 200X 2016 version. To get back to my first question is it possible to tig braze aluminum?
https://www.youtube.com/watch?v=Nm1VfYEOC50
Postby LtBadd » Mon Feb 05, 2018 8:35 pm
Hello adksigns
Can you provide more information as to the function or purpose of the tube that you want to braze? This would be helpful in giving the best advice for your situation.
Do you have any photos or drawings of the design?
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby adksigns » Tue Feb 06, 2018 9:02 am
Looking for a way to Tig braze using less heat to the joints.
Joining 3/16 OD x .035 Aluminum
Picture below
adksigns
Next
