bruce991
    Tue Jan 05, 2016 10:31 pm
    Central Michigan
I am curious on a outside aluminum joint weld how do you get best results with overlapping one surface entirely over the butt end of the other piece that is perpendicular? Or only half way on both thus welding into a valley on outside. I would think the latter would give better strength in the weld as the full over lap your welding a seam with less contact. Reason I ask I have a storage box job to weld using 1/8 in sheet aluminum into a rectangular storage box. Thanks
    Sun Nov 19, 2017 10:09 am
I do corner to corner.
Everlast 210 EXT
CJ737
bruce991 wrote: Or only half way on both thus welding into a valley on outside. I would think the latter would give better strength in the weld as the full over lap your welding a seam with less contact. Reason I ask I have a storage box job to weld using 1/8 in sheet aluminum into a rectangular storage box. Thanks
Yes, I agree, however the fitup is a little more work but not difficult
After reading your post again, I'll clarify with this pic.
Edge joint.jpg (5.47 KiB) Viewed 550 times
bruce991
    Central Michigan
Sorry didn't get back I would say that is my choice as well, thanks.
