bb1127
    Wed Feb 26, 2014 11:25 pm
Hello to all, I have a job welding 1/2” stainless and was wondering if anyone could give me some advice on weld settings and tungsten and cup size? Will I need tungsten bigger than 3/32?
Thanks
Plate? Tubing? Pipe? Application? Position?
3/32 tungsten is fine.
#8 or larger cup (me, I'd use a ceramic #12 Fupa)
Purge line and tinfoil at the ready.
Can't know the amps without the other details.
bb1127
It is plate, fillet welds flat on a table.
Is it beveled or just 2 plates flat togeather? Do you need full penetration? Can it be welded from both sides?
bb1127
It is not beveled but it can be if I need to. Full penetration. Yes it will be welded on all sides.
Like pulling teeth...
BillE.Dee
    Mon Nov 27, 2017 8:53 pm
Ever hear of pocket teeth?
    Sun Nov 19, 2017 10:09 am
cj737 wrote:Like pulling teeth...
LOL!
Everlast 210 EXT
CJ737
bb1127
Thanks guys y’all have really helped clear the water.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
In Australia we would never dream of welding stainless that thick with the tig. Mig all the way. Maybe even a dual shield flux core.
    Mon Feb 26, 2018 1:52 am
    Idaho
The do make 308L stick rods and MIG wire for $$$.
    Australia; Victoria
Amazing what you can get in exchange for legal tender.
VA-Sawyer
    Tue Jul 31, 2018 12:56 am
    Candler, NC
Unless you have a free source of Stainless tig rod, I think the cost of filler will be similar across the three methods. Time required will be the big factor.
    Idaho
1/2 plate/bar is pretty doable with a good bevel/multipass weldment. So agreed, pretty much any process will do the job. Tig is what I would go for with stainless. Fit-up really tight.
    Australia; Victoria
Don't forget it's a fillet weld. I know it's a thing in the USA, but we hardly ever see structures welded with tig. Only pipes.
    Thu Jan 24, 2013 12:13 pm
Norm in the UK for structural in 1/2" would be stick unless it's a high volume repetitive part - then Mig.
