    Fri Jun 18, 2021 1:19 am
hi,
i want to learn tig welding for my header project(subaru boxer engine) .
my settings is,
16l/min argon
1.6mm tungsten(gray)
2mm electrode(308l)
number 7 cup
and 92A for 2mm 304 stainless
some welds are very bad i know, i want to practice so, i didn't wait cooling or cleaning etc.
some welds are without filler and i didn't make bevel my main concern is stainless pipe welding(304l now)
i would appreciate if you have any suggestions
Your cup is a limiting factor. I would not weld stainless with less than a #8 and only that small if it were out of position piping. For flat, lap, or tubing a #10-#12 all day long with a quality gas lens.
92 amps is high heat unless your travel speed is fast enough. Hard to do for new welders. Also filler could drop in size. I tend to use 70-75% of the 1amp/0.000 formula with stainless. If the material is 0.090 I’d run 70 amps, maybe 75 with filler. I also tend to run filler 1/2 the diameter max for tubing.
If you want to practice stainless, practice good habits. LET IT COOL. You can not make good decisions from bad choices.
Got Lumens?
    Thu Jun 17, 2021 12:40 pm
When fusion welding(no filer) try and keep the speed even and tungsten centered directing heat on only at the weld joint. With the right technique and heat you should have smooth rainbow weld. Start small try only welding as far as your wrist allows ~25mm or so. You should try welding a "T" by tacking the bottom with a second piece in the middle at a 90. Try both fusion and with filler. This will give You a feel for how it acts and can pull toward the weld side.
Jack Ryan
    Wed Mar 24, 2021 10:20 pm
    Adelaide, Australia
Has the term "fusion welding" been redefined? I have noticed several people (no shots being fired) and some WEB sites call fusion welding without a filler "fusion welding". Fusion welding was always defined as (roughly) joining by melting parts together - whether or not a filler was used. Examples of fusion welding are ARC (Stick) and MIG. An example on non-fusion welding is brazing.
Some welding organisations (eg AWS) define autogenous welding as fusion welding without a filler.
Thanks
Jack
Got Lumens?
Thanks
Jack
Brazing adds solder. I have fusion welded brass to brass. It may be just me, but when I was taught 30+ years ago in TIG welding, not adding any material to a joint and joining two pieces using just the arc of the torch was referred to as fusion welding.
Jack Ryan
    Adelaide, Australia
Got Lumens? wrote: Brazing adds solder. I have fusion welded brass to brass.
Brazing does not melt the base metal, that is why it is not fusion welding. Only the filler metal (not generally called solder) melts.
It is fusion welding but it is still fusion welding if filler is added.
Apologies to the OP for the interjection.
Jack
Brazing is adhesion not fusion.
gnabgib
    Tue Nov 10, 2009 1:55 am
Nice to have a challenge, but how about practicing on the easy stuff first. I wouldn't be starting on thin material. Or on stainless!
cj737 wrote:Your cup is a limiting factor. I would not weld stainless with less than a #8 and only that small if it were out of position piping. For flat, lap, or tubing a #10-#12 all day long with a quality gas lens.
*like*
Years and years ago when I was building/customizing long-tube headers, I dabbled with stainless but at the time it was too time-consuming, and the overall difficulty level was more than I wanted to invest. I ended up with mild steel, but regardless, those items mentioned are a MUST
  • #12 or larger, #16-#18 preferable
  • 0.7A per 0.001" material thickness is about all you need (maximum set at the machine can be higher, but it needs to be modulated by the footpedal.
  • 2mm is roughly 0.080", so filler diameter should be no larger than 1.2mm (0.045")
  • Heat MUST be allowed to dissipate/extracted, whether by letting itself cool on it's own, or actively wicking the heat out through other means, such as additional aluminum/copper mass/chill-bars. There is no escaping this!
oh, and stop weaving the dang torch around like a drunk driver! :lol: Get the basics down first, then you can try for the "instagram" money shots. 8-)
Thanks for your suggestions,
i bought gas lense and bigger cup but not arrived yet.
i have thicker materials, but stainless, i have to find non stainless.
i read every message again and again,
my work space is little small first i'll build bench table and practice with steel
gnabgib
Ok. Come back when you can show us some decent welds in mild steel.
There is no harm in practicing on stainless. Just do your best to incorporate some good habits and equipment changes until you have other material also.
I like welding stainless. It’s tricky, but is damn pretty if done right.
thanks for your replies
i worked first stainless because, I want to learn tig welding because of my hobbies and, they are all stainless(for now)
mild steel is easier and i'll try
but i'm struggling my hands are shaking(no illness or alcoholism)
my arm is getting tired probably because i don't get enough support from the table
It is really important to be physically comfortable if at all possible. Do not let your arms support your body weight. Your hands should hold the torch very lightly and use your arm to move the torch, not your fingers or hand. Always take a few practice strokes to move the torch along your weld path to insure you are free, comfy, and no obstructions.
And breathe!!! If you are gripping the torch, you'll shake. If you are holding your breath, you'll shake after a few seconds. If you are trying to push the torch with your fingers, you'll shake. Relax, there's no life or death involved here. Turn on some music and just find a rhythm. This will take hours to get competent so you might as well enjoy the journey :)
Got Lumens?
+1 to that /\
Wells
    Tue Jun 22, 2021 9:34 pm
I’m fairly new as well, and I’m trying to learn not to prop with my wrist stationary (easier but limits range and can curve off at the end) but set up so that I can slide along parallel to the weld. It’s not easy... Best advice I’ve gotten is to have a bunch of drops available to prop/slide on. I have pieces of cold rolled round and square tubing pieces, and will plop then down on the table in front of, and parallel to, the weld. The edge of the table will sometimes be fine, but I’ve found that I can get my hands into a more comfortable position by using something matching the height I need, and that I can position at any angle. Cold-rolled because smooth is better, and I’ve buffed some of the pieces so they will slide even easier.
I’m sure others with more experience can add more tips about positioning aids than me,
Wells
Weld ON
    Tue Mar 09, 2021 5:09 pm
[quote="semih"]hi,
my settings is,
16l/min argon : IF YOU ARE SO REACH THEN YES BUT NORMAL IS 12L/M
1.6mm tungsten(gray) FOR LEARNING IS BETTER 2.4 MORE STABLE AND WILL NOT BEND IF YOU DO SOMETHING WRONG
2mm electrode(308l) YOU MEAN ROD 308 OR 309 ARE FOR WELDING METAL WITH SS TOGETHER STANDARD ROD IS 304 OR 316 , FOR LERNING 2MM IS OK BUT NOT FOR WELDING IF PLATE IS 2MM THEN 1 - 1.6MM RODE
number 7 cup FOR LEARNIG USE CUP 6 AND DO 12L/MIN
and 92A for 2mm 304 stainless 92AMPS FOR 2MM IS TO MUCH FOR LEARNING , THAT MEANS MORE AMPS THEN FASTER YOU NEED TO RUN ..:) SO YOU NEED FIRST TECHNIQUE AND THEN SPEED UP , USE ALUMIUM BELOW IF YOU WANT TO RUN 92 I WILL DO 65 - 70 AMPS
DONT WORRY YOU DOING GREAT JUST NEED MORE PRACTICE AND TRY TO FOLLOW WHAT I SAID ABOVE
i made welding table and my hand shaking is over, no more shake
Thanks for all messages, i read again and again every suggestion
i want to make diy vise and i welded L brackets for vise and pipes for practice
i cut pipes with angle grinder first they were not straight so my welds are not straight but later i bought saw for cutting
some welds are fusion some welds are with rod if there is a gap i welded with rod
Amps 55
12l/min
1.6 mm grey tungsten
Number 7 cup(my cups and gas lenses were not arrived yet)
Looks much improved. Don’t forget for final weld, purging is a must for proper results.
Got Lumens?
Looks much better, congrats.
The fusion welds can be colorful.
When needing to add rod, it will
most likely blacken the weld, and
need polishing if necessary.
thanks for your messages, i'm hobbyist but i want to do right way
now i'm trying weld with purge
hi again,
i'm trying to weld with purging
first welds with no gap and no bevel(just i want to try) and i did not do full penetration(I welded it with variable amperage so I could experiment, between 75-100amps)
than i welded with gap(about 0,024"(0,6mm)) and no bevel (about 90 amps, 8cfh purge)
I did the welding on the outside for the first time without the purge for testing purposes, please ignore it.
I think I couldn't adjust the gap very well, but thanks to the purge inside, I was able to catch the proper penetration, even if it was partial(i saw gold/colorless color inside)
now i'm looking my photos are junk sorry
The gapped and purged weld looks great. When you have a gap, tack in several places. Then expect the gap to close during welding due to material expansion, especially stainless. If you stay with Sch10 piping, you may need to increase the gap and filler, 1/16 for gap, 3/32 for filler. This may change your amperage requirements too.
Hi,
It's been a long time and I've only just started making header lol.
First i made up pipe, it's 60mm diameter and 3mm thickness 304.
I beveled about 37 degree and almost no gap. Purged and i guess penetration is good, amp was about 80 with pedal
What I want to ask is, weld height in the two connections is a little low
will it be problem for me ? will i do second pass ?
Regards,
Semih
Don’t do a second pass. If the weld is fully penetrated through to the inside, you’re perfectly fine for strength. Stainless welds are very, very strong. I have made lots of stainless headers, mid-pipes, even welded up the exhaust manifolds and up/Y pipe on my diesel and never used filler. They are still going strong after 9 years. But, all of this welding was done with a complete, careful purge.
That has to be your rule: internal purge and full penetration for exhausts.
Realize that stainless won’t corrode like carbon steel, but it also will crack due to thousands of heat cycles if not welded properly. Carbon steel exhausts don’t have this cracking tendency but they corrode. Trade offs for both materials. The welding procedure becomes your decision criteria: if you’re willing to do it properly, stainless is the advantage.
Lastly, I think you could reduce the wall thickness a LOT for that pipe. For an up pipe, 0.063 is more than adequate. Headers and mid-pipes I use 321 stainless and 0.053-0.039 depending upon the vehicle.
