MCMIG85
    Mon Nov 01, 2021 10:55 am
I have a 20 cubic foot tank for my MIG welder. It's probably the smallest size of tank you can get at approximately 16" tall. I just got it filled with 75% Argon/25% CO2. I'm wondering what PSI this size of tank should read when full? It's reading 700 PSI after being filled.
nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
That sounds low. My 18cf hobby argon is 1400 and I don't like that.
VA-Sawyer
    Tue Jul 31, 2018 12:56 am
    Candler, NC
Near the top, or on the neck, look for the letters DOT. The standard, such as 3AA follows, and then the rated pressure in PSI. This applies in the USA, other standards are used in different countries.
MCMIG85
VA-Sawyer wrote: Thu Mar 24, 2022 11:14 pm Near the top, or on the neck, look for the letters DOT. The standard, such as 3AA follows, and then the rated pressure in PSI. This applies in the USA, other standards are used in different countries.
Mine says DOT-3AA2015. So I'm guessing my tan is rated to 2015 PSI?
    Wed Jan 22, 2014 12:00 am
    Connecticut
You got ripped off. Should be at least 2000psi, give or take +/- 100 psi for temperature changes
Multimatic 255
