It is currently Thu Feb 22, 2018 6:44 am Advanced search
The what I welded today (/whenever) thread (pics please)
Postby GreinTime » Sun Sep 10, 2017 11:32 pm
LtBadd wrote:looks real good Sam, are you just tacking and welding or doing the cutting of the pipe also?
I cut the tubes on a lathe and then used a miter gage on a belt sander to sand the angle. This was all done before I left on Friday, I just took everything home to weld it.
Postby mpete53 » Mon Sep 11, 2017 10:27 pm
I love seeing all the great looking weld posted here. Myself, I wanted to learn tig welding to do small fabrication and repair of stainless steel parts for boats. Today I was able to help a friend by welding a mount back onto a porthole frame. Not a lot of welding just 4 tacks from 16 gauge to .025. While it was not the best looking weld it made him smile.
also 2 other small boat projects
arm to prevent rotation of radar mast
tie down point added to 5/16 washer
porthole repair
mpete53
Postby 5th Street Fab » Sat Sep 16, 2017 11:28 am
This last month or soImageImageImageImageImageImageImageImageImage
5th Street Fab
Postby 5th Street Fab » Sat Sep 16, 2017 11:35 am
Some moreImageImageImageImageImageImageImageImageImage
5th Street Fab
Postby motox » Sat Sep 16, 2017 2:17 pm
5th St.,
not only do you do outstanding welds but your shop fabs the neatest
projects!!
motox
Postby 5th Street Fab » Sat Sep 16, 2017 3:04 pm
motox wrote:5th St.,
projects!!
Thanks bud I really appreciate it!
5th Street Fab
Postby 5th Street Fab » Sat Sep 16, 2017 3:07 pm
projects!!
5th Street Fab
Postby ESENTI » Sun Sep 17, 2017 2:27 pm
Seems perfect well done.Very nice bright welding I wonder what is the flow of argon gas protection isi perfect and how you can achieve this king of shine weld apart the skill that it is obvious that is outstanding...Bravo.. Some how o pro must show
quality of welding that is ahead of the average welder .
ESENTI
Postby Poland308 » Sun Sep 17, 2017 6:36 pm
Started working last night on a 16 inch 300# steam main under ground. There still digging up pipe trying to find the leak. It has an insulation case and a welded 24inch jacket. If they can't find the leak visually then there going to bring in a smart pig. It's a robot that can ultrasound the pipe from the inside. Either way we will be cutting off the jacket and repairing the pipe, or cutting out some holes big enough to get the robot in. We only have a one week window so it may not all happen this week. I'll post more pics as I can.
Postby 5th Street Fab » Fri Sep 22, 2017 12:35 am
This weekImageImageImageImageImageImage
5th Street Fab
PreviousNext
