Page 99 of 131
Posted: Fri Apr 14, 2017 7:54 am
by exnailpounder
Otto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
TLAR....I'm gonna steal that from you
Posted: Fri Apr 14, 2017 6:56 pm
exnailpounder wrote:Otto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
Be my guest! I also estimate time on task by the WAG method, which is "Wild-Ass Guess". I always look like a hero, because I use Thomas Edison's rule... However long I think it will take, I double it, then add ten percent, and that's what I tell them.
Under-promise and over-deliver, and they'll beat down your door.
Posted: Fri Apr 14, 2017 8:45 pm
I use the Edison method as well! I just didn't know that's what it was called.
Posted: Fri Apr 14, 2017 10:34 pm
by RocketSurgeon
It's been a while since I posted anything substantial.
First time on 304 SS 1 1/2", 1" and 1/2" sch 40. Two passes. Argon purge at 10cfh. 3/32 2%Thoriated with #7 cup (wishing it was an 8).
Posted: Mon Apr 17, 2017 8:07 pm
by GreinTime
Posted: Mon Apr 17, 2017 8:30 pm
by exnailpounder
Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
Posted: Tue Apr 18, 2017 1:37 pm
by GreinTime
exnailpounder wrote:Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
No, these guys are anti pulse lol. I welded 1/2-5/8" at a time, mainly because that outer shell is 0.020-0.030" thick in some places. Monster 16 nozzle at 40-45cfh. I don't remember if I included that bit.
Posted: Wed Apr 19, 2017 8:10 am
by MosquitoMoto
Very nice work, Sam.
K
Posted: Wed Apr 19, 2017 12:58 pm
by pgk
Beautiful work Sam.
Pete
Posted: Wed Apr 19, 2017 4:57 pm
by motox
great looking work Sam.
real men need cups !
Posted: Wed Apr 19, 2017 8:20 pm
by Barrett
1.5" chromoly tubing joint. Any tips are appreciated
Posted: Thu Apr 20, 2017 8:56 am
by Rick_H
Here's a random batch of pics from stuff I've been working on, I do post on my Instagram account a good bit of your interested. RNHFAB
Posted: Thu Apr 20, 2017 12:10 pm
by 5th Street Fab
Posted: Thu Apr 20, 2017 1:50 pm
by Olivero
AAAAAAAAAAAAAAAAAAAAAAAAAAAND now I remember why I never go to this thread
Posted: Thu Apr 20, 2017 2:38 pm
Good stuff Rick and 5th St.
Posted: Thu Apr 20, 2017 4:11 pm
by motox
rick
beautiful job on the box corner!!!
Posted: Thu Apr 20, 2017 5:18 pm
by ex framie
I'm so inadequate.
Thanks guys.
Very nice work the pair of you.
Posted: Thu Apr 20, 2017 9:35 pm
Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
NONE of these weldporn jockeys came out of the womb doing that, and every one has had their share of epic fails before they got consistent, and a few more before they were good.
NEVER put yourself down because your weld doesn't look like so-and-so's. If you're six months in, and he's been doing it 30 years, you can't expect to be on par.
Posted: Fri Apr 21, 2017 7:10 pm
by jernigan78
Aloha guys. Ill jump in on this. Some stuff from this week. Mostly fishing stuff. 316 stainless stuff. Mahalo
Posted: Fri Apr 21, 2017 7:18 pm
by exnailpounder
Otto Nobedder wrote:Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
And also realize..if you do the same thing every day you better damned well get or be good at it or you'll be down the road. It's the guys that have to wear all the hats that impress me
Posted: Fri Apr 21, 2017 9:49 pm
by Rick_H
Recycling an old filler bowl to make something else...
.065" tubing, .020" bowl
Posted: Fri Apr 21, 2017 9:56 pm
by Coldman
I love repurposing stuff. It means someone saw the potential in something that others would have trashed. Nice work Rick.
Sent using Tapatalk
Posted: Fri Apr 21, 2017 11:31 pm
by nelson
I welded something by mistake thinking it's aluminum casting but it worked.... what the hell?
It's too heavy and fairly magnetic. The aluminum stuck....what is it?
Posted: Fri Apr 21, 2017 11:32 pm
by nelson
I can't post 2 pictures for some reason...
Posted: Sat Apr 22, 2017 10:39 pm
by bruce991
Made this smoker box for a friend this weekend. Adding legs right now. One heavy SOB 1/4 inch plate 22 by 14 inches. Putting a grate inside tomorrow.
