Just mucking around with some outside corner joints on 16ga stainless.. I experimented using pulse, as well as filler and no filler joints. All joints were welded with a 3/32" 2% Lanthanated Tungsten, Furick Fupa 12 with aluminium angle for backing. I had 100 amps set on the machine but didn't go anywhere near that..I think I had about 12LPM argon flow.
No pulse, 1/16" 308L filler:
1pps, 100 amps, 30% peak current and 20% background current, 1/16" 308L filler:
Same settings as above sans filler:
I only ran 6 coupons but I can definitely see the benefit that using a smaller diameter tungsten and filler would have on thin material.
Flo
way to lay it down Flo, very niceOzFlo wrote:Just mucking around with some outside corner joints on 16ga stainless.. I experimented using pulse, as well as filler and no filler joints. All joints were welded with a 3/32" 2% Lanthanated Tungsten, Furick Fupa 12 with aluminium angle for backing. I had 100 amps set on the machine but didn't go anywhere near that..I think I had about 12LPM argon flow.
Flo
Thanks Richard. This is the same material that I'm going to build my water cooler reservoir from so I want to get some good practice before attempting to weld that up. I didn't use any chill bars on the face side of the material when I welded those coupons but definitely will be when I attempt the real thing.LtBadd wrote: way to lay it down Flo, very nice
Flo
Make sure to document your build, we'll all benefit from itOzFlo wrote: Thanks Richard. This is the same material that I'm going to build my water cooler reservoir from so I want to get some good practice before attempting to weld that up. I didn't use any chill bars on the face side of the material when I welded those coupons but definitely will be when I attempt the real thing.
Flo
- MosquitoMoto
Was stuck in the shop waiting for deliveries. Got sick of doing paperwork so went into the shop and knocked up a third hand from scrap. The 1/4" round came from a mop squeezer already bent to perfect shape, just had to cut it to length. All three points got aluminium bronzed to eliminate sparking.
Deliveries came, too late to go back to site and I missed lunch so what would do you think an aussie joker would do about that?
Ah Queensland, beautiful one day, perfect the next.
- 3rd hand.jpg (85.71 KiB) Viewed 2576 times
- bbq.jpg (102.94 KiB) Viewed 2576 times
A few from the week. The first ones were tough. The main tubes were 0.6 mm (0.024") wall. A little nerve racking!
Stephen S by Mike Zanconato, on Flickr
The rest were a little more chill. Typical 0.7 - 0.8 mm wall.
Bill S by Mike Zanconato, on Flickr
Rich R by Mike Zanconato, on Flickr
Dan A by Mike Zanconato, on Flickr
Wall thikness dosent efect on the strenght of the pipe, only material and outside diameter. You can apply the same force in pipe or axle... until there is a litle dent in the pipe.
i have made controllarms for race cars with 0.8mm wall thikness pipe, material 4130. Worked great. Cant take any dents, but is same for the stiffness than hevier wall pipe.
Yeah! We got our ASME "R" stamp qual yesterday. This li'l root pass was enough to send the fire marshal and board inspectors over the edge. I then went to lunch with them and the bosses and stuffed myself full. Great bunch of folk.
It'll be 3-4 weeks before we have our certificate and stamp, but code work can proceed.
Steve
Steve
- ASME qual.jpg (26.11 KiB) Viewed 2823 times
- MosquitoMoto
Thanks, guys! I have one procedure and test left... One vessel in the queue is aluminum, so I have to qualify separately, and qualify a separate procedure.
Steve
Steve
- 5th Street Fab
Last month or so I have ore pics of each if anyone wants more
- 5th Street Fab
