Page 110 of 131
Posted: Thu Aug 10, 2017 8:45 pm
by zank
A few from the week. The first ones were tough. The main tubes were 0.6 mm (0.024") wall. A little nerve racking!
Stephen S by
Mike Zanconato, on Flickr
Stephen S by
Stephen S by
The rest were a little more chill. Typical 0.7 - 0.8 mm wall.
Bill S by
Rich R by
Dan A by
Rich R by
Posted: Thu Aug 10, 2017 9:38 pm
by Coldman
Beautiful work as usual Zank!
0.6mm is gettin pretty thin. How does it go for strength, is there a weight limit for the rider?
Posted: Fri Aug 11, 2017 5:24 am
by VooDoo
Wall thikness dosent efect on the strenght of the pipe, only material and outside diameter. You can apply the same force in pipe or axle... until there is a litle dent in the pipe.
i have made controllarms for race cars with 0.8mm wall thikness pipe, material 4130. Worked great. Cant take any dents, but is same for the stiffness than hevier wall pipe.
Posted: Fri Aug 11, 2017 5:33 am
by Coldman
Well you're wrong about that. You're just operating at a lower factor of safety. If you did the strength calculations you would know this to be true.
Sent using Tapatalk
Posted: Fri Aug 11, 2017 12:58 pm
by VooDoo
Thats true that the longevity of the part goes down with thin wall, but dosent effect the torsional stiffness much. Not problem @ racing (cars.. bikes..)
Posted: Fri Aug 11, 2017 4:14 pm
Yeah! We got our ASME "R" stamp qual yesterday. This li'l root pass was enough to send the fire marshal and board inspectors over the edge. I then went to lunch with them and the bosses and stuffed myself full. Great bunch of folk.
It'll be 3-4 weeks before we have our certificate and stamp, but code work can proceed.
Steve
- ASME qual.jpg (26.11 KiB) Viewed 2915 times
Posted: Fri Aug 11, 2017 7:16 pm
by Coldman
Great news Steve, well done. I recon the feeling might better than a standing ovation.
Sent using Tapatalk
Posted: Fri Aug 11, 2017 11:18 pm
Well done!
Posted: Sat Aug 12, 2017 6:28 am
Congratulations Steve
Posted: Sun Aug 13, 2017 8:29 pm
by OzFlo
Well done Steve!
Posted: Mon Aug 14, 2017 7:56 am
by MosquitoMoto
Great stuff Steve!
Moz
Posted: Mon Aug 14, 2017 6:05 pm
Thanks, guys! I have one procedure and test left... One vessel in the queue is aluminum, so I have to qualify separately, and qualify a separate procedure.
Steve
Posted: Mon Aug 14, 2017 6:15 pm
by zank
Good luck on the last one, Steve! Congrats so far!
Posted: Mon Aug 14, 2017 10:18 pm
by 5th Street Fab
Posted: Mon Aug 14, 2017 11:04 pm
by 5th Street Fab
Posted: Tue Aug 15, 2017 8:02 am
by OzFlo
Nice work 5th Street! Very nice..
Posted: Tue Aug 15, 2017 8:23 am
by MosquitoMoto
Good grief...inspiring work.
K
Posted: Wed Aug 16, 2017 10:46 am
by pgk
Looks awesome 5th
Posted: Wed Aug 16, 2017 7:05 pm
by Bingo
Some p91 field weld OD prep for phaser ray this is a power house main steam line. The system runs at 1950 degrees at 2400 psi. The weld shot good time for drinks!
Posted: Wed Aug 16, 2017 7:19 pm
by Onenastycummins
this looks sick, what kind of machine you use?
Posted: Wed Aug 16, 2017 9:37 pm
by 5th Street Fab
Onenastycummins wrote:this looks sick, what kind of machine you use?
Thanks everyone.
I run syncrowave 250dx's
Posted: Thu Aug 17, 2017 5:24 am
by motox
5th st
what do you use to cutout the aluminum parts?
Posted: Thu Aug 17, 2017 9:22 pm
by 5th Street Fab
motox wrote:5th st
We have a router table for the main parts. Then we just use a shear or band saw for everything else.
Posted: Sun Aug 27, 2017 6:13 pm
by GreinTime
Some 9th Gen Civic Turbo manifolds getting done after hours.
Posted: Fri Sep 01, 2017 12:07 am
by dirtmidget33
