Page 113 of 131
Posted: Sun Oct 29, 2017 2:30 am
by Donniev
kiwi2wheels wrote:Donniev wrote:We didn't figure for any distortion in the pipe, it's there but not a concern. I bet if we Lasered the flanges the middle one would be 1/4" or so lower than the end ones... distortion isnt something that's typically thought about on the bigger stuff, especially here since install is going to be flange/ butterfly/ flange...bolts will pull it back no problem.
How do you start a project like that ?
Do you start from the center and use that as a reference to maintain the horizontal tolerance across the flange faces ?
Or do your comments above apply ?
I've been welding the 68 4" flanges. Weld it up, measure 7" from center of weld make a mark. 2 hole the flange, mark top dead center at my 7" mark and then we have a plastic template to mark the saddle cut, instead of a pipe wrap.
To weld them onto the 12" piece we turn the 12" on its side to 2 hole the first 4" flange...then turn it so the holes are facing up, and keep the 2 hole pins in the first flange that's now tacked. To get all the others we put 2 hole pins in the next flange to be tacked and use a 2' level laying flat on the faces of the flanges, the first one tacked and good to go, and we use the level sitting on the face of the flanges get the rest. Just push the 2 hole pins on the flanges tight to the level, now your 2 holed. Sorry for the book, not sure how to better describe it. And really with 2 holing, even if we get a tiny bit off it's ok, you got some play with the bolts, just can't be too far off.
We roll it over after they're all tacked and check 1 or 2 flanges quick to make sure we're good...haven't cut any tacks yet...o and we start at one end or the other
Posted: Sun Oct 29, 2017 5:33 am
by kiwi2wheels
[quote="Donniev"
I've been welding the 68 4" flanges........................................
We roll it over after they're all tacked and check 1 or 2 flanges quick to make sure we're good...haven't cut any tacks yet...o and we start at one end or the other[/quote]
Thanks for your reply.
Posted: Sun Oct 29, 2017 7:11 am
Makes sense, nice looking pipe spool
Last shop I worked we had a T-Drill machine that would pull the tee in schedule 10 stainless.
- sch 10 316 with rolled victaulic grooves
- IMG_0003a.jpg (38.25 KiB) Viewed 3542 times
Posted: Sun Oct 29, 2017 9:12 pm
by Donniev
Lt I don't have a ton of experience with ss, that stuff pull on you bad? I've welded sch 10 before, boss watched me like a hawk to make sure I wasn't going too slow when I was welding it
Posted: Mon Oct 30, 2017 4:30 am
Donniev wrote:Lt I don't have a ton of experience with ss, that stuff pull on you bad? I've welded sch 10 before, boss watched me like a hawk to make sure I wasn't going too slow when I was welding it
Yes, it'll move easily. We use a level to make sure all the ports are true to each other.
Posted: Mon Oct 30, 2017 9:33 pm
by RamboBaby
My new job is gravy. And it pays good too.
Posted: Mon Oct 30, 2017 10:35 pm
by Coldman
Great news baby! Remember where you were a couple of years ago? Look how far you've come today by toughing it out, working hard, gaining experience and chasing your dream.
Congrats and well done.
Posted: Tue Oct 31, 2017 8:07 pm
by Oni
Finished up a turbo manifold this weekend for a land speed Harley. It's my first time doing a turbo manifold, pretty happy with how it came out.
Posted: Tue Oct 31, 2017 8:11 pm
by Oni
Also welded the bottom on a fuel sump that my buddy machined for his turbo bike.
Posted: Tue Oct 31, 2017 8:18 pm
@Oni
Nice looking welds and fab work
Posted: Tue Oct 31, 2017 8:26 pm
by Oni
@LtBadd
Thank you sir
Posted: Wed Nov 01, 2017 1:29 am
by reflexsa
Hi all,
I lasercut a few more of the stainless practice cubes and tried an el cheapo pyrex gas lens.
I'm not sure if the increased coverage gave me less discoloration or if I was welding colder (or faster...). I tried to not remove too much of the material when welding.
I also added a max current control on my foot pedal which made the range more controllable.
It was really nice to see some pretty colours in the welds instead of the dull grey I have been getting.
I have my original cube and the one I did most recently. I don't think my filler feeding consistency is any better yet.
- 20170916_191423.jpg (23 KiB) Viewed 3887 times
- 20171029_120845.jpg (32.74 KiB) Viewed 3887 times
- 20171029_150827.jpg (47.67 KiB) Viewed 3887 times
- IMG-20171029-WA0006.jpg (45.88 KiB) Viewed 3887 times
Posted: Wed Nov 01, 2017 6:34 pm
reflexsa wrote:Hi all,
Certainly looks better, does your machine have the ability to pulse? You could use a slow pulse setting to help time the addition of filler and give a more consistent looking bead
Posted: Wed Nov 01, 2017 9:14 pm
- 1CD7B940-2C08-4E34-B617-DF459C4EFA9B.jpeg (28.02 KiB) Viewed 3844 times
Last weekend. Pressure vessel repairs. Didn’t include all the photos but ground out an old coupling and welded in a new one. Plus made a repair on another pin hole on the coupling on the left. With the pt test you can see the stress crack that developed on the edge of the HAZ. Had to grind that out full depth as well. Beveled the base metal and the coupling. Then had to add a fillet per code so that I didn’t have to back weld from the inside.
Posted: Thu Nov 02, 2017 1:49 am
by reflexsa
LtBadd wrote:reflexsa wrote:Hi all,
Yes it does have pulse just haven't really had a chance to fiddle in detail with all the settings. My Argon and scrap supplies are running low at the moment haha.
I think it is almost time to construct something a bit more useful
Posted: Fri Nov 03, 2017 11:13 pm
by 5th Street Fab
Posted: Sat Nov 04, 2017 6:05 am
by motox
5th
so those flanges are welded outside top flange inside bottom flange?
nice work as always.
Posted: Sat Nov 04, 2017 1:49 pm
by 5th Street Fab
motox wrote:5th
Thanks bud and yes I weld the fillet first before I put the other piece on. Then I weld the top with the outside corner.
Sent from my XT1635-01 using Tapatalk
Posted: Wed Nov 08, 2017 11:15 am
by GreinTime
Posted: Wed Nov 08, 2017 10:58 pm
Nice projects! It’s amazing how much metal you can put down when you start working with thick stuff like that.
Posted: Wed Nov 15, 2017 3:54 pm
by Warrenh
Its been a busy two week span. 4 spiral staircases and a poling platform. You really cant complain about being busy.
Posted: Wed Nov 15, 2017 3:55 pm
by Warrenh
Posted: Thu Nov 16, 2017 8:50 am
by motox
Warrenh
nice work .
clean and neat!
Posted: Thu Nov 16, 2017 9:30 am
by TheBeardedWelder
Not sure if this belongs herem but one of the mini sculptures ive created
- 20170613_091221_HDR.jpg (39.43 KiB) Viewed 4027 times
Posted: Thu Nov 16, 2017 5:25 pm
Very nice!
