    Sun Jan 15, 2017 1:08 am
Cncdave wrote:
aland wrote:Those welds are looking pretty spanky there 5th Street! :)
these were all done with your technique of “Jam on the peddle, feed rod, move,wait,jam on peddle, feed rod,move, wait...etc??
No just consistent foot pedal add filler mover add filler move etc. I do use that technique but only when it's very thick and not preheated.
Sent from my XT1635-01 using Tapatalk
BigD
    Thu Jan 07, 2016 1:56 pm
Moving my wastegate straight to the turbine housing for real boost control, the WG is so huge (V60) that I didn't have a nice way to dump it so I decided to do a smokestack. Can't wait to hear how it sounds (in addition to the 4" Ti side exit exhaust I plan to do)
Also haven't done aluminum for a while so didn't want to get rusty. I'd been looking for a calf raise for my basement gym but haven't found anything reasonably priced that isn't shit. So I picked up a few pads, a pair of pillow bearings, dug through my metal supplier's offcuts for 1/4" tubing and made my own. Even put to use the spare shift knob I got with my 4 speed. I sorta expected it to fail as I use a lot of weight for calf raises but it's giving me faith in my work. The middle thigh pad post sees a lot of load and been serving me well
aland
    Thu Dec 28, 2017 11:10 pm
Cncdave wrote:these were all done with your technique of “Jam on the peddle, feed rod, move,wait,jam on peddle, feed rod,move, wait...etc??
Cncdave wrote:Sorry, pedal.[WINKING FACE]
I understood. ;)
I'm going to give that method a try for a welding cart I am going to build.
As you jam on the pedal, I'm guessing you watch the puddle for it to get bright, and feed the rod, then move the arc forward, pause briefly and shampoo, lather rinse, repeat ???
I'm gonna practice on some scrap first, and will test various things out...the pedal seems better than using pulse, but I've seen people using 1-1.5 frequency on the pulse to get a similar effect.
My angle grinder died... which sucks. I bought one off ebay, but it hasn't arrived yet.
EDIT: Never mind, I found this video that Jody did. Seems Jody push the rod in as he pulses the pedal.
Alan
I understood. ;)
Alan
Ya kinda like that. With aluminum you're adding quite a bit of filler. I step on the pedal and start adding filler until the puddle is as wide as I like then taper off on the pedal while still adding filler until the puddle is calm then rinse and repeat. It all takes less then a second so it takes a bit of practice
    Mon Jul 25, 2016 7:31 pm
    Gainesville, Ga
Just messin around with some stainless
sq1920 20180119_134513.jpg (57.99 KiB) Viewed 3847 times
    Sun Nov 19, 2017 10:09 am
Look'n good Billy Ray.
Everlast 210 EXT
CJ737
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
Tag weld from one of our Civic Downpipes a few weeks ago, and an Intercooler weld from today!ImageImage
Sent from my VS996 using Tapatalk
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Nice to hear from you. Great jobs as well.
Sent using Tapatalk
    Thu Jan 24, 2013 12:13 pm
+1
Looks really nice work & it's great when a familiar name returns on the forum - sadly a few have fallen recently - more newbies here now than vets.
Do keep posting pics if only to remind me how bad my eyesight is & Tig is best left to the young guns !
Very nice welds, good to see you stopped by Sam ;)
Warrenh
    Thu Apr 27, 2017 12:31 pm
A flying bridge for a 28 foot boat. The first set are the original build to the customer's specs. He wanted all the lines from the bottom structure to continue into the top and the front legs had to land on top of the bottom pipes for control wire accesd. After completion he decided it was too tall. I had to cut it down 8 inches. I added kickers to match the bottom. Those are the second set of pics.
Also some interior rails that were built in place at a beach house in Panama City Beach.ImageImageImageImageImageImageImage
Beautiful work! How long did the boat railing take you to build?
Everlast 210 EXT
CJ737
Warrenh
I had about 40 hours in the boat including the rework. Thanks, also. I like the boat work.
Warrenh
I had some pictures of railings for a home in Sandestin Resort. It was an interesting design. Built In the shop and installed by us ImageImageImageImageImage
Coldman
    Oz
My daughter recons I need more exercise so she bought me a flatpak bike to ride in front of the tv at night instead if drinking beer and eating chips. My objection was more to questionable quality and suitability coming from a flat box, she assured me she researched it thoroughly and it would be suitable for me. She said if I peddled hard enough maybe I could make it to the beer fridge.
I assembled it, turns out it was made for the vertically challenged.
So I took it to the shop, cut it up and re-welded it with 3/4" sched40 pipe extensions to the seat and handlebars.
It fits me now and works. The peddle radius is still a little small, the peddle arms I need to look at closely as they may be die cast. The seat needs to be re-worked as currently it messes with my junk. The friction brake on the wheel is noisy. Overall the ergonomics is a fail but it was cheap right?
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
cold
i suggest a camelback for hands free beer distribution......
Set up your phone to take video first, I want to see what happens when the physical activity releases the carbonation. :lol:
Coldman
    Oz
No way. If the government find out they might reintroduce the carbon tax :)
Sent using Tapatalk
Heya guys here's a big flag pole I built a while back. It was somewhere around 130" tall. The center holds some type of lightImageImageImageImageImageImageImage
You have beautiful welds, and you know it. Why don't you contribute here and help us out, to get where you're at?
Everlast 210 EXT
CJ737
motox
    Delaware
5th
you must buy filler by the truck load!
tungstendipper wrote:You have beautiful welds, and you know it. Why don't you contribute here and help us out, to get where you're at?
Sure ask any questions you want and I'll do my best to answer them.
Warrenh
Some new cantilevered, rolling gates ready for installation. All aluminum construction.ImageImage
motox
    Delaware
Warren
awesome!
do you have a close up of how your joining pieces in the top photo
are made?
motox wrote:Warren
awesome!
are made?
And why does it look like every other vertical piece isn't welded?
