ironmike
    Fri Apr 30, 2010 10:14 am
Under what setups is back purging normally used? I T'd off the outlet side of my regulator for a purge line & turned up the flow rate to compensate for the tap loss of pressure. Is this a totally bad move, & if so, any ideas short of buying a dual reg?
pro mod steve
    Wed Mar 31, 2010 12:47 am
Check my post and it will tell you what not to buy to backpurge.
