dbeau
    Wed Jun 02, 2010 4:53 pm
Is is possible to tig weld brass to mild steel and if so what should the filler material be?
tigamajig
    Wed May 26, 2010 8:23 pm
high frequency....use an aluminum setting,and brass rodsthat are available for O/A brazing...sand them clean with scotch-brite pad or sanding cloth to remove varnish/dip .... I have personally repaired several Airco Air arc whips, when the brass lugs were broken or burnt off....blow me if i'm wrong , but high frequency seems to be the only electric arc method that works on conductive and highly conductive metals. :mrgreen:
lancer101
    Wed Jul 21, 2010 8:57 pm
Silcone-bronze filler rod. Gotta get the heat on the brass and than work from there.
