Jason_alex
    Fri Jan 24, 2014 1:41 pm
Hey guys, I am having my intermittent problem with my syncowave 350 again where when I press on the foot pedal I get really low power like 5 amps max. But when I flip it to the panel for amperage it works great give me the power as it should..... any ideas where to start hunting this problem down at?
jrogers80
    Sun Aug 03, 2014 10:13 pm
Have you tried checking the wires all the way from the pins to the potentiometer? See if you are getting a good connection on all wires.
Jason_alex
I checked it last them then plugged it back in and it worked again for a while would you check it why it is still plugged in on the back side of the cannon plug?
