    Wed Oct 15, 2014 9:29 am
Tungsten grinding on cheap China bench grinders grrrrr I'm done with that its on now!
Here are the first bits, the blue diamond wheel is 180 grit, the yellow diamond wheel is 320. Those are lathe chuck guards I'm hoping to use them instead of the dinky grinder eye shields. I have had bits of metal in my eye twice, I'm not looking for a third trip to the ER for that.
I'm not messing around with a stand either, this is the larger Baldor cast iron stand, 120 lbs, get some!
The 1/2hp 7 inch Baldor grinder arrived, model 762. Here it is vs the 6 inch China bench grinder. Its quite a bit larger.
The arbor is .625 inch for the 7 inch wheels, that's a burly 15/16 inch nut.
These are the supplied aluminum washers .625 arbor, they appear to be cast and don't exactly spin true but the fit has enough slop that they are fine.
Houston we have a problem. So I turned on grinder and it took off across the bench with some speed, whoa there Baldor. Severe vibration. Here's the problem, the motor shaft is actually .750 they turn down the outer few inches to .625 for the grinding wheels and washers. But that big steel inner spacer doesn't fully cover the .750 section of shaft, there's a .060 x .060 shoulder sticking out. The large aluminum washers were resting on that cockeyed instead of up against the tall steel spacer, hence the vibration.
I turned a couple of 1.25 inch tall brass shims on my lathe with a recess for that shoulder, problem solved. I also turned a couple of brass .625 x 1.25 arbor adaptors for the diamond wheels.
Here's an action shot, vibration is now quite minimal, it just sits there purring. Run out measured on the outer edge of the 6 inch diamond wheels is .0035 left, .0040 right that's pretty good.
This stand is for the larger Baldor grinders, I'll have to fabricate an adapter to bolt it down but the feet fit fine on the cast iron flats. Note the holes in the base they are a whopping .900 a bit overkill.
I may fabricate different tool rests for grinding the tungsten, something at the proper angle, maybe a groove for 2-3 of the common Tungsten sizes, and in aluminum to draw the heat out of the tungsten during grinding they get hot.
This was the other manufacturing defect. The bottom/third hole for the outer wheel covers was not tapped and no screws were included. They also appear to have used self tapping screws on the other two, the threads were crap. I tapped the third holes 10/32 and chased the threads on the others. I replaced the screws with stainless allen head machine screws since I want to be able to swap out grinding wheels and use this for other grinding purposes.
Here's the bottom of the Baldor stand just for reference. Its 17x20 by the way.
Next...this motor can be run in reverse Baldor notes the wires to reverse in the manual. I may buy a 4 pole DT on/off/on switch. It would be easier to grind the tungsten with the wheels rotating up and away from me. I see guys on youtube grinding on the top of the wheel against the rotation. I ground a few that way but stuck the Tungsten in the China grinding wheel 2-3 times, once shattering the Tungsten. The danger is bits of Tungsten flying up from below perhaps getting under my safety glasses, I'm hoping the lathe shields will take care of that.
That's all for now, stay tuned.
Nice work on the fixes. I'm sure your tungstens will come out excellent on it. Luckily I haven't had any issues with my Lowes Skil 6" bench grinder. :)
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Very nice....that base is a beast we have them on our bnch grinders at work.
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Impressed.
Certainly beats my inverted $20 belt sander... :shock:
Moz
Oscar wrote:Nice work on the fixes. I'm sure your tungstens will come out excellent on it. Luckily I haven't had any issues with my Lowes Skil 6" bench grinder. :)
I had purchased a better quality 100 grit grinding stone for the China grinder. I ruined it the first day by snapping off the tips of 3 or 4 Tungsten's in the wheel rendering that part of the wheel unusable. Then a Tungsten caught in the wobble-o-mattic wheel hit the tool rest and shattered into multiple pieces. :o
    Wed Jun 10, 2015 1:48 pm
    Memphis Tennessee
Thats the same setup that the lincoln electric welding school uses for their tungstens. Awesome set up!
Tyler
Tjschur
    Wed Oct 23, 2013 8:14 am
    Fairfield, CT.
Where did you source those diamond wheels from.
Thanks.
McMasterCarr http://www.mcmaster.com/#diamond-grindi ... ls/=yc4q41
Knowing what I know today I'd just buy the 320 grit diamond wheel for Tungsten and put a normal stone wheel on the other side of the grinder.
I originally purchased the 180 grit diamond wheel thinking it would be even smoother than the 100 grit stone wheel I had been using. And maybe it is under a magnifying glass but a tungsten ground on the 180 grit diamond wheel looks rougher than one ground on the 100 grit stone wheel. Maybe the diamond grit is just sharper I don't know. But like I said if I had it to do over I'd just buy the 320 grit diamond wheel and go with a stone wheel on the other side of the grinder.
Here are close up pics of 3/32 Tungsten ground with the two diamond wheels vs the made in USA 120 grit stone wheel.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Hmmmm
Big Difference! Very surprising difference actually?
Do you think the stone wheel will introduce impurities?
Your comment on the best result? Diamond vs Stone?
BTW, impressive close-up photos, thanks!
The Lincoln Electric Welding School is using the 180 grit blue diamond wheel, they have over 5,000 grinds on it. So while not as smooth looking as the 320 grit yellow diamond wheel I'm sure its fine.
The Tungsten ground on the stone wheel looks the smoothest yet its a courser grit. But it looks less ground and more melted to me. I can tell you the tungsten gets much hotter when grinding on the stone wheel. That wheel is also polluted from grinding tungsten's dipped in the puddle.
cptjackm
    Sat Oct 03, 2009 10:46 pm
    Newbury Park, California
Coolidge wrote:The Lincoln Electric Welding School is using the 180 grit blue diamond wheel, they have over 5,000 grinds on it. So while not as smooth looking as the 320 grit yellow diamond wheel I'm sure its fine.
Coment:
Coolidge goes to the head of the class with this Baldor & diamond wheel.
I think you have something regarding the contaminated wheel.
I break off the lump when it occurs or use a second grinder with a coarse wheel
in preparation for the finish grind.
And yes, great close up pics.
Jack
Gavin Melville
    Fri Jul 03, 2015 6:31 am
    Christchurch, New Zealand
I removed the wheel from both ends of one of these, http://www.topmaq.co.nz/item/view/ALLWI ... u=MEGR4100 , removed the flexible shaft, and used the parts to lock a diamond blade on. Works brilliantly. The blades look like this http://gstraders.co.nz/product/3%E2%80% ... -of-three/
The edge has enough diamonds to notch a tungsten, so it can be snapped. The face works perfectly, perhaps 3000 rpm is a bit slow, but under a microscope the results look perfect. Blades are us$3 each.
