A/C is a little different than DCEN. Lincoln shows the input current for only 1 phase of the typical 220v 2 phase circuit. Typically this is done because folks often look at the breaker and refer to it as a 50amp circuit when in fact it's two 50 amp circuits.dustelf wrote:well, u know better , but it seems somehow weird to me, u are using around 9kwh that is way too much for a 200Amp tig welder, about double.
please post info about the helium mix, Im ashemed to say , but i've never used it.
The 225 is a square wave TIG but is still a transfomer and not an inverter. If you set the machine in A/C mode to be 50% clean and 50% penetration then the output amps on the digital readout is correct. If you set the machine up to be 25/75 then that is a 50% difference in phase duration. The current builds for 50% longer and has a 50% shorter cooling period. The result is that even though you're not using any more current, you are creating and effectively storing more heat. Heat is what causes the breaker to trip. The welder can put out 250amps max in A/C mode.
In theory changing to a 50amp breaker would work but it would also void my Home Owners policy if it caused a fire.
I had to get the 50/50 out of another warehouse so I won't get it until Monday or Tuesday. I let you all know how things changed later next week.
Thanks again..
