Nice stuff , 1st grade
Mine is smaller btw , nobody's gonna touch it
good idea, ill take a pic today of the insides, there has to be enough penetration to not fall off obviously and hold 30psi of pressure, also the inside has to be fairly smooth with no burn through markings. everything is mandrel bent so welding on the outside of bends is a pita sometimes since its alot thinner
Hey gurew - nice looking work. Just curious, to weld around those aluminum bungs/nipples, how many arc stops / torch repositions / arc starts are you doing? I've always had trouble maintaining a constant torch angle while welding around small circular things like that, without doing a whole lots of repositionings. I can do it in fewer torch repositionings, if I start the torch angle pointing backward away from the filler, and end pointing way aggressively forwards, usually stop when my filler rod gets too toasty. Although it works, it doesn't give the most uniform ripple pattern doing it that way.
176 amp, 120hz, pulse it with the foot on and off, i do about 3 beads then reposition. if you are steady enough it will look like 1 pass no start/stop...trust me it can be done and i do it daily
ill post some more pics in a second
Thanks for the info. Whenever I restart on aluminum, I get a frosty cleaning band around the restart area on the previously laid down weld beads. I think I can see that in some of your beads too. I think a flex head torch might help a lot with being able to put the torch in the position I need while maintaining some range of motion to pivot in my torch wrist. (I am just using a rigid head, 17 series type one.) I'd like to try out a CK Flex-loc.
from what i see in the auto industry, you have 2 main types of torch.... 20 and 9. the 20 is water cooled, the 9 is air cooled..both are super tiny torches compared to the wp17 which is huge and a pain in the ass to use...
you can pick up a wp-9 torch with all the collets etc.. for under $50, if you cant find one local for cheap ill get you one at my cost which is way cheaper than you will find online most likely...
Thanks gurew. I just melted my 150 amp air cooled torch on a 3/8" aluminum sign project using my machine's max 200 amps. I need to upgrade the torch, but 125 amp air cooled would be a step backwards for my needs. I am considering water cooled now, or perhaps 200 amp air cooled.
idk, i use the wp-9 daily at 180amps welding aluminum...im sure if you use it long and hard and heat it up good it will burn up...just take breaks...
but yes, watercooled is the way to go, i had a wp-20 torch with a bernard 2500ss and it was awesome, never got hot....soon i will go back to water cooled
i decided to post a video of me welding some stuff, i dont have any through lens stuff yet but in time i guess...
im welding the 2 aluminum pipes together that have been coped and tack welded in place. i have to crank these out fairly quick at work seeing as i have about 50 of them to do, when i have some free time i weld them a hair slower and the beads are super nice like the pics i post, but all of these get powdercoated black afterwards...
http://www.youtube.com/watch?v=17-U2BE9wCs
Nice looking work. You might consider picking up some leather welding sleeves to protect your arms. Harbor freight actually has a pair for just $4. (There may be "better quality" available elsewhere.) Great to throw on over your bare arms when your welding short sleeved.
I picked up a "stubby collet body" for my 150 amp air cooled that I am going to try, which basically adapts a 9/20 series cup to fit a 17 series torch. I'm looking forward to trying it.
fitment was my sub par...i was trying to have this part done before the end of the work day with only 1 .5 hours to fab and weld. going on the boss' car so i def should have made the fitment better on the seams.
usually i have stuff like this waterjet cut or sheared and the parts come out dead nuts and fit flawless with a perfect gap...even a 1/32 gap change in this thin of alum makes a world of difference in how the bead control is
either way im semi happy about it!, its a battery tray for a datsun 510
damn, i'm wishing for a 911 almost all of my life
about the second class, well u got some end craters that could be nicer
here's a 6g weld I did playn with some pulse setings, 304ss
- Photo0101.jpg (46.23 KiB) Viewed 1335 times
weld looks straight, looks a little hot to me... how thick is that material?
when i weld stainless i will literally do 5 beads and stop postflow and start again after a 30 seconds for cooling. and you have seen my stainless welds
Hey grewru,
Where did you find a hood big enough to fit over that inflated head of yours? Just curious, because your are an average welder at best.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
it's 1,5mm wall , no gap 40A L1 , ~28 L2 , 1,5 sec l1 and 0,2 sec l2.
but that was just training in 6g pos and goofing with pulse. almost never had to weld anything at 45 in a factory, some 800 OD steam pipes ..
inside looks like this
- Photo0106s.JPG (31.06 KiB) Viewed 1138 times
it's not hot at all, the wall is very thin, 1 pass , freehand.gurew wrote:weld looks straight, looks a little hot to me... how thick is that material?
if you stop after 5 beads will take too long to weld one pipe and increase the chance for craters, let's just say it would be luck to pass an xray, some ppl (walkers) make only one stop, but they work on the bench and i get those hanging from a scafold jobs.
i know in the automotive industry, welds with that color would create cracks later on a turbo manifold out of sch40 308 SS pipe, entire wastegate runners would break off etc... i havent had the chance to xray any of my welds but ive yet to have a manifold come back i would think that 1600-1800 degrees under stress of a turbo and pressures from the exhaust pulses would be in the "extreme" category
