racingparts
    Sat Nov 13, 2010 2:43 am
Hello to everybody on this forum!! I'm Mac
i'm new here, all the way from Romania
i just started my tig welding and the videos on youtube helped a lot i might say.
i have a problem welding a 1,5mm thick pipe on the 3mm alu plate
do you have any advice on how to do that?
the problem is the pipe that is thinner then the plate .so it melts
this is exactly what i must obtain, so if you have some tips about how to do it, i would be gratefull
rickbreezy
    Sat Oct 03, 2009 10:08 pm
    Norfolk, Va
my advice is to weld a bead on the plate first, then to turn your amperag down and connect that bead to the pipe by welding. this will give you tighter control in what you are doing, and the weld bead will melt quicker than if you had only the 2 peices. this is hrd to explain though, do you understand?
tigmaster
    Sat Oct 23, 2010 10:24 pm
no, forget that crap, just focus more of your heat to tthicker plate and move quick, alum heats up quick
jakeru
    Sun Apr 25, 2010 3:30 pm
Angle your torch so the tungsten is pointing more at the thicker, continuous plate than the thinner, pipe edge. That should transfer more arc heat into the thicker, continuous section, to the point where if you do it just right, you'll have similar sized puddles on both sides, at about the same time. You need to also not be too tentative about it, and use enough current (IE: use full expected welding current) to get this to work. Otherwise with too weak an amount of current, the arc may just jump around erratically, and you'll have no directional control with your torch.
When you have your two puddles formed of similar size on each side of the welding gap, with split second timing and filler rod feeding hand accuracy, dab the end of your filler rod right between the two puddles. When its all going well, surface tension pulls the film of the two puddles tight into a single puddle, making them into one fused molten puddle. Then, move your torch a bit alog the weld bead, wait for the puddle to melt into a "C" shape, and when you see that "C" shape dab your filler into the middle to make surface tension pull the puddle tight into one round puddle again. Repeat, over and over again.
tigmaster
and u gotta move quick...good explanation up thereto bro
racingparts
thanks a lot guys!
Monday i will give it a try
today i practiced some T welding am stacked a lot of dimes in order to do it right
also worked with the settings a lot in order to find the best settings for everything that i have to weld
i still have to get right welding the shape of L on the outside 90° angle, i'll try it again with less amperage in order not to melt the edge. Any advice for this one? (it's same as welding a box) don't seem to get it right for now
For the 3mm plate the amperage i use is 70A base current (BC)and 140 Pulse current (PC), PW 0,5 pulse width, 1.6mm or 2.4 tungsten and 6cup size
30% AC balance and AC freq 100Hz
this is my welder Image
pro mod steve
    Wed Mar 31, 2010 12:47 am
I am a noob still and probably will always be since there is so much to learn please don't bash me too much. Could the frequency be turned up to put more focus on the torch? just a thought.
Joe
  • Joe
  • Active Member
    Tue Jul 27, 2010 7:52 pm
Interesting that the welder in the picture looks exactly like my Everlast PowerPro 205 except for the color.
racingparts
Joe wrote:Interesting that the welder in the picture looks exactly like my Everlast PowerPro 205 except for the color.
both are made in china :oops:
but let's say the quality it's great and dont cost a few pennies but over 1000$
tigmaster
wow really....where do u get that machine...ive got a miller lift arc 150...would love to have alum cap.
Joe
  • Joe
  • Active Member
Check out Everlast Welders for a USA source.
racingparts
i can't make those welds :oops:
i cant make a nice weld around the small pipe like in the photo
it's more difficult than i thought
tomorrow i'll give it another try
dustelf
    Wed Oct 13, 2010 10:09 am
    Rotterdam
racingparts wrote:i can't make those welds :oops:
wow, so welding is not that easy afterall, i bet a monkey can do it tho...
racingparts
welding the T, L forms are ok now, i have no problem doing those
but the pipe i cant
i'm welding it , but it doesn't look so nice as in the photo
dustelf
    Rotterdam
de weld in the foto is defective anyway.
racingparts
dustelf wrote:de weld in the foto is defective anyway.
for what's is needed it's more than perfect
any good advice about how to do it?
dustelf
    Rotterdam
no, it's far from perfect, you just don't know that.
and for advise , go to UTS Timisoara and learn to weld before you kill someone.
mrprism
    Wed Oct 13, 2010 7:03 pm
dustelf wrote:no, it's far from perfect, you just don't know that.
Could you please enlighten us as to why these welds are "far from perfect" and possibly could kill someone? I'm trying to see what you're talking about but the only thing I'm seeing is the small crater left after the arc start in the bead. I thought the welds look really good :?: then again I'm not a welding inspector either.
Alan
dustelf
    Rotterdam
Alan
First that crater is at the end of the weld not at the start, it is called an end crater also.
You should know a weld can look "really" good and still not be good at the same time, don't have to be an welding inspector, and btw there are 2 end craters in that pic, one is better , but i had microfissures in craters looking better then that.
That part is going to be on a motorcycle, would you ride a bike whith parts welded by someone who learns Tig welding on youtube?
And then those are not his welds, he is trying to copy what you see in that foto.
Remi
    Mon Oct 05, 2009 3:09 am
jakeru wrote:When you have your two puddles formed of similar size on each side of the welding gap, with split second timing and filler rod feeding hand accuracy, dab the end of your filler rod right between the two puddles. When its all going well, surface tension pulls the film of the two puddles tight into a single puddle, making them into one fused molten puddle. Then, move your torch a bit alog the weld bead, wait for the puddle to melt into a "C" shape, and when you see that "C" shape dab your filler into the middle to make surface tension pull the puddle tight into one round puddle again. Repeat, over and over again.
This the best "How to start a fillet weld" description I've ever read. Hats off !
Remi
sschefer
    Wed Aug 18, 2010 7:44 pm
Hey guy's Dustelf is right, those weld craters will form cracks and if you look a bit closer, the welds are also contaminated and porous.
anthonyfawley
    Fri Apr 23, 2010 6:58 pm
A good weld could be ugly.. but more importantly a good looking weld could also be dangerous
BLAZO
    Thu Dec 24, 2009 7:11 am
Hi bro. I would preheet 3 mm plate and then weld them together. It will lower the gap of melting point.
Sorry for my bad English.
racingparts
i'm starting to think that preheat is the only way to go
i'll give it a try, and lower the amps in order not to blow the pipe that melts instantly otherwise
