Stevo450
    Sat Apr 16, 2016 11:37 pm
Wow! An overwhelming number of positive comments with the general go-for-it! Pretty excited and now would like advice on a good TIG welder...
BRAND?
MODEL?
ACCESSORIES? ( electrodes, foot pedal, gas lens, filler wire...I dunno anything worth getting )
PPE?
GAS?
Once I've acquired a machine I'd probably start practicing on some mild steel and aluminium ( bear that in mind when suggesting accessories :) )
So what is a good grade of aluminium to practice on?
Obviously there are a number of basic welds I'll need to work on ( lap joins etc ) but what's a good way to start?
Lots of questions..............
Stevo450 wrote:a good TIG welder...
BRAND?
MODEL?
PPE?
GAS?
What's your budget for a machine?
Stevo450
BRAND?
MODEL?
PPE?
GAS?
I'm willing to spend up to ( maybe more ) $2500 AUD....
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Stevo -
After absolute minimum dabbling with stick, I started out on Tig, with a focus on aluminium. As others have said, so much comes down to seat time and you will use up a LOT of argon. And that is expensive.
I am reasonably happy with my progress and can now weld strong, functional parts, although I wouldn't go so far as to call them pretty yet. In my early days I was out at the bench every single night welding scrap, watching videos, welding more, taking notes. Take plenty of notes!
I don't have any association with Tokentools but I can recommend them. My Metalmaster Elite 215 cost under $2K and will handle low and fairly high amp work, all metals. It also has an onboard stick welder and plasma cutter, which is handy. Pete at Tokentools really backs up his stuff - call him and he will help you, no doubt about it. In my opinion that counts for a lot.
One tip - if you deal with Pete at Token, be sure to specify a smaller torch than the mega sized 26 that comes standard with the welding machine.
Have fun!
Kym
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
When starting out buy the tig "TRICK" :lol: accessory of the week till one figures out it is seat time practice as stated.
Practice and notes and more practice. Most of the welds one does will never be seen except by the welder,self analyse important.
One will learn new word usage :roll: and have fun.. This forum can be helpful.
series 9 or 20 ,style torches, with super flex hoses, proved most useful to me.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
weldit321@gmail.com
    Wed Feb 24, 2016 11:52 pm
    Waco, Texas
Get an everlast 256s Its an AC/DC Tig, Stick, Plasma cutter combo unit for around $1800 USD. It has pulse settings which could help you with getting good bead appearance on tig welding before you master pedal control. I've had mine for a little over 3 years and love it. They come with a 5 year warranty and are easy to figure out (dont let all the dials confuse you)Image
    The Land Down Under
Just FYI for the OP, I have heard it said on several occasions that the Metalmaster (Tokentools) machine is simply the Everlast machine (above) rebranded.
Don't know this for sure but they look like twins - same features, basically one is green, the other red, some differences in the user interface. Like the Everlast machine in the states, the Metalmaster in Australia also carries a 5 year warranty.
Again, I have no business association with Tokentools, have just had good experiences dealing with them.
Kym
Harry72
    Sun Nov 30, 2014 6:59 am
    Australia
If you intend to weld ally you will need at least a 200amp machine... your budget will just cover that including a bottle of gas.
What ever you do dont be fooled by the cheaper Chinese machines, here in oz this will leave you with brands like token tools and Everlast... Unimig newer models. CIG and WIA do have machines in this price range but they a low on features you may need in the near future. Most American brands here are exuberantly priced and aimed more towards the professionals.
And yeah as others have said be specific about what torch you want when you order your machine... I just upgraded mine from a wp18 @12' long to a CK20 (wp20 style)@25' long superflex cables and it was just over $700 AU.
My machine is a Everlast 210ext and W300 water cooler and E2 sized bottle... with this torch added Im hitting over $4k and then come all the consumable bits!
    The Land Down Under
Just some more thoughts as they come to mind for the benefit (hopefully) of the OP:
Before purchasing I had folks tell me "Forget different wave forms, forget pulse, you'll never use that stuff." But I started using those features within a couple month of receiving the machine. Very handy.
I was also told that a memory function on the machine was just a gimmick, but I now use it all the time. When you find the perfect settings for a material/job, it's great to be able to call them up again later at the touch of a button.
Finally, some people reckoned that the generalised 'welding for dummies' AC and DC settings on my machine would be a crutch - I'd never learn to set up the machine myself, I'd just use these numpty settings all the time. I found quite the opposite - using these to start with helped build my confidence very quickly in the early days. Now and then today they are still handy as a reference point when I am setting up the machine.
Hope this stuff is helpful, anyhow.
Kym
Stevo450
Again a big thanks to everyone for their inputs!! It's really encouraging to get all these positive responses to my question and a the info given is definitely making me this very carefully about what machine I should be looking at before I dive in and buy the first TIG machine I see!
I would love one with stick/arc welding and plasma but those are bonuses.
As for brand I'm a sucker for 'brand names' only because I've been burn by 'cheap' stuff before-not saying that suggested machines are no good I'll just need a LOT of convincing before I buy.
Perhaps in my quest for a machine I should maybe ask for the machines ratings ( amps output ) and features-pulse settings, square wave etc etc the reason I want a rather I depth machine is because I plan to develop ( over time of corse ) my TIG welding skills to the point where I would have to use the functions that come with the machine...
Hope that makes sense.....?
I gues I'm going to have to get myself geared up for a larger than expected outlay for a TIG!
    The Land Down Under
Hey Stevo.
Yes, it's good to get down to the details and research all the features and ratings of each machine, no doubt about it.
If you decide to look further into the Metalmaster stuff, all of this - duty, amps, features - is listed on their website or of course you can just call Pete and talk to him.
Brand names? I wanted a Miller Dynasty, but decided against extending my mortgage in the end. Just too much cash for me as a hobbyist. Be aware that in Australia, the well-known and trusted brands tend to be made in China anyhow, unless you go for something like a Kemppi.
In the end I wound up Googling the dealer and the welder type and for my choice I found overwhelmingly positive feedback, which is what counts...great service reputation and a human being on the end of the phone to back you up.
I think your plan to buy a fully featured machine and 'grow into it' makes a lot of sense. I'd hate to buy a very basic machine and find myself wanting more capability shortly thereafter.
Regarding my machine, I am already exploring various wave forms. One of Jody's videos on welding 1.6mm wall aluminium tube called for Triangle Wave. I gave this a shot and it worked a treat! I'm also using pulse pretty often, and I definitely value the ability to crank the amps down low for super thin stuff and still enjoy great arc starts. Practising and exploring pretty much every evening, there's a lot to enjoy with a fully featured machine.
All the best with your research and your decision, whatever your choice. My only regret with Tig is that I didn't get into it 10 years earlier!
Kym
TWENTY B
    Sun May 07, 2017 6:44 pm
So after a year how is your progress?
I'm about to start down the same path with a unimig razorweld 200 ac/dc
mpete53
    Sun Mar 06, 2016 11:33 am
    New York
As I see it, when you buy most tig machines, you are also getting a stick machine. So, you can learn two types of welding.
    Tue Dec 13, 2016 9:24 pm
    Clearwater Florida
Stick and TIG are just about the 2 processes allowing you to do pretty much anything you want, MIG is like the speed up of stick in my opinion and a speed up for aluminum welding as well. Makes it go quicker but less control.
YES!! :D
And now you are one of the club :lol: :lol:
Helmet time cures most problems,if not just ask, many here willing to help,settings and pictures get response. ;)
Everlast 250EX
