I guess it the gas?
I took the torch apart, (end cap and all cup end fittings off) unplugged the lead from the welder (gas feed separate connection) plugged both sides of the torch head with my fingers. When I pressed the peddle the flow meter jumped up as it pressurized the lines then went to zero, so the quick connect , hose and head are gas tight.
I then reassembled and did the soapy water test. I got a few bubbles, the largest about the size of a pea after 10 seconds of gas flow. This would seem to be a very small percentage of the gas flow at 20 cfh. I then using good quality stretchy electrical tape, I taped the joint between the end cap and torch body and tried the spot test again no better.
Does this all sound like a good torch leak test? Can anyone add to what I should try?
Thanks
Mark
Nothing like giving a new welder a 40 page list of things to confuse him even more.
Is it possible that you have a bad bottle of argon? Yes. Is it more likely that the problem is the tank vs something you are still doing wrong? Not really.
If you take the tank back to your supplier they'll probably swap it out for free if you tell them it is bad. If it isn't hard to do that, why not. At least you'll know one way or another.
Just to sanity check though... You are running pure argon not 75:25 right? Those salmon color spots were with an on time of like a second right? You aren't cranking the gas flow rate way up to shield better right?
-Sandow
Something to be said about just getting torch time and worrying about perfection later... Get so torch time on mild steel where the material is cheaper and it matters less if you have some oxygen in your shielding gas.exnailpounder wrote:You should try welding
-Sandow
-Charles Dickens
-Charles Dickens
the tank is labeled Argon. No sparks or splatter.
The last test may be a little high on the flow 20 cfh and a #6 nozzle.
My steel welds don't look that nice either.
May have a chance to get access to another tank just to check if it is the gas
If I can't, It's only an 80 cf tank, and as you all say I need the torch time so I plan to run it out
Thanks
Mark
Thanks
Mark
- Braehill
Mark,
Any leak is a bad leak and sometimes the small leaks cause big problems as they are the ones that draw atmosphere in instead of blowing Argon out.
Another thing that needs to be looked at is your collet, if they are twisted and swollen, they restrict flow through the torch head. The best cure for this is to pick up the CK wedge collets and call it a day, they last almost forever and can't twist.
An 80cf bottle is one of the most likely candidates for moisture. They are usually bumped up to pressure off another (bank of) cylinder without ever being evacuated under a vacuum to remove moisture. If you own the cylinder and they fill it while you wait, this is almost assuredly what's happening. Get an inline moisture filter from Harbor Freight or the like and put it in the low pressure side of your system. Better yet, get a cheap vacuum pump while you're there and draw your cylinder down to vacuum overnight before you take it to be re-filled.
All that being said, I'm with the camp that says "who cares if it's not shiny". I weld quite a bit of small diameter heavy walled stainless piping and I'm here to tell you that most of it isn't shiny by the 3rd pass. Even if the weld itself is still shiny, the HAZ is definitely not. Did I overheat the pipe an inch on either side of the weld? Probably not, but it has reached a critical temperature in which it can oxidize without gas coverage. Shiny welds are achievable, but they come at a cost that most people in industry wouldn't be willing to pay. There are millions of dull stainless welds holding all manner things together all over the planet. Brush it and move on to the next weld.
Just my opinion, but if you're going for shiny, you're going to need a lot bigger Argon cylinder. It's all about gas coverage and get moving.
mpete53 wrote:My weld polish up good enough for my needs so as long as strong and stainless.
So I guess its time to just keep welding and get better if not as shiny as I would like, welds.
Thanks
Mark
Yup,but don't forget what you have learned in this thread. Welding with contaminated gas is relevant to welding with blunt tungsten. In worst case arc wanders and no matter what you do your welds look completely awful.
Change the bottle when the time comes and check if anything chances. Also fix those leaks when you have enough spare time. After all you can't improve your skills very far if machines aren't working properly.
-Markus-
I just started welding Stainless today, whatcha think
In all seriousness this I welded with my Jumbo CK gas saver (1-1/8"), 1/16" tung, 60amps 2.5pps 50%/50%, travel speed is fairly quick, full penetration with a back purge. Your doing fine, lots of good guys and experience on this site that will help point you in the right direction. Practice, Practice and more practice
- brushed...
- pipe2.jpg (26.94 KiB) Viewed 1784 times
- just welded 316L
- pipe.jpg (57.73 KiB) Viewed 1784 times
update
I am getting better. I still can't get the hang of the higher amperage welds you all talk about so I tried lower amps and a .040 tungsten and it seems to work for me'. I well keep trying those higher amp om practice plates though.
Plate weld: 16 gauge 304 stainless, no filler metal, 35 amps .040 tungsten #8 gas lens 20 cfh and resting on a 1/4 aluminum plate
Pole: about 14 gauge 316stainless with a internal stainless sleeve. Mostly without filler, 35 amps .040 tungsten #8 gas lens 20 cfh
brackets: 1/8 x7/8 unknown stainless pins welded no filler rest with 309. 45 amp 1/16 tungsten #8 gas lens 20 cfh. not yacht grade but cleans up enough for a work boat,
Thanks for your help
Mark
Mark
- IMG_1154s.jpg (55.57 KiB) Viewed 1756 times
- DLewis0289
By George I think you got it! Looks good, keep burning only way is up from here.
I got a new Lincoln auto darkening welding helmet. What a difference from my old harbor freight darkening. Also got the cheater lens.
I can now see the puddle and the arc clearly. Being able to see lets me get the arc much shorter creating much less heat.
Weld shown is thin walled tube to 10 gauge plate. The only post weld treatment was a light wire brushing.
Thanks again for the help
Mark
Mark
- IMG_1158.JPG (98.43 KiB) Viewed 1730 times
Looking better Mark, its amazing what you can do when you can seempete53 wrote:I got a new Lincoln auto darkening welding helmet. What a difference from my old harbor freight darkening. Also got the cheater lens.
Mark
