Maybe start listening to it, we are trying to help. You are friggin cooking it. You said you listened to the advice but instead started playing with torch angle. Forget all the settings you are using. Turn up the amp to the max on the machine. Argon 15-20 CFH. USE THE REMOTE, that's what it's for. Setting it at 100, 160, whatever you set it at only sets the TOP limit of amperage available when the pedal or finger slide is maxed out. I can duplicate the same results you are seeing if I set my machine for 20 amps and floor the pedal and heat soak the part.mpete53 wrote: I am getting the advice I asked for.
Ryan
Miller Dynasty 350 w/wireless pedal
Miller 350P with standard torch and XR-Aluma-Pro
Miller Multimatic 200 w/spool gun w/wireless pedal
Miller Spectrum 375 X-TREME
Smith torches
Optrel e684
Miller Digital Elite
Miller Weld-Mask
Smith torches
Optrel e684
Miller Weld-Mask
Maybe I did not make myself clear
I am happy for all the advice I have been receiving.
I am trying to follow the advice.
I do not in any way mean any disrespect to those giving the advice.
I am sorry if I am a slow learner and am not progressing as fast as some may like (my self included)
I don't weld all day, I grab a hour here and there. I am not a welder by trade, but have done small jobs stick welding for many years. I always loved the look of a nicely done tig weld and now it could make such small, light gauge welds.
Why am I working with stainless? In a word BOATS. I have sailed all my life and there is always something to repair or a small bracket to make and I would like to use tig rather than stick welding.
Thanks again for your help
Mark
Mark
Hello Mark
Let me try to help you.
1. First try to get a perfectly silver puddle.
Clean the metal etc. as you did before. Flush the torch with argon, because moisture goes inside the hose/torch cable and it can take even minutes to clear it away.
After this, set couple of second to your preflow and then set postflow to maximum 15 or 25 sec or whatever it is in your machine. Then light an arc on clean metal, melt a puddle and end the arc and don't remove the cup until postflow is ended. Don't put too much amperes, because we are welding stainless and it won't need that much as carbon. I would just use 50 amps no matter how thick your plate is.
Also try to make quite small puddle a size of a water drop and don't use filler. Also don't keep as long tungsten as Jody. He is doing it for the video purposes.
If you manage to get silver "spot" weld... Congratulations you have no leaks!
I you have color on your weld...... You have a leak somewhere in your system. Perhaps in torch or inside the machine or even on regulator o-ring.... or your gas lense might be broken and creates vortex..... Or you might have even a bad bottle of argon. Sometimes there is bottles that contains moisture due to problems at filling station.
Here is a Jody's good example:
Did you made this far?
2. After getting a silver puddle it is time to focus on welding of stainless steels.
- Austenitics stainless (304,316 etc) steels needs less amperes than carbon steel, because they conducts heat poorly.
- Getting a perfect color of your weld is mainly "fashion" thing. Stainless weld can be gray and it's no problem at all.
- Keeping a filler rod inside the gas shield during welding is extremely important. Otherwise you oxidize the filler and those oxides gets in the weld, but won't melt completely.
- Try to get thinner beads. First practice withouth filler and then start adding filler when you feel comfortable. Try to use smaller rods first. This helps with the heat as you don't need to re-heat a junk of massive filler on the weld etc... Try different sizea and you will figure it out yourself.
-Markus-
PS:
Here is a orbital weld that shows a tiny bit of grey. Absolutely OK. People always tends to prefer silver and pink colors, because those are very nice looking. Truth is that in some cases it is impossible to get even pink color unless you don't want to waste argon and use trailing shield or something like that.
-Markus-
PS:
-Markus-
You're doing fine. I didn't see anywhere in any of your posts that you disrespected anyone. You can practice on mild steel until you get better with your timing and adding filler. It welds almost the same but it disapates heat a little better but you can still cook it. It's cheaper and good to practice with. At least you didn't come here having never tig welded and want to master aluminum right away. You know how you get to Carnegie Hall right? Let us know how you are doing.mpete53 wrote:Maybe I did not make myself clear
Mark
Markus made a very important point..
"- Getting a perfect color of your weld is mainly "fashion" thing. Stainless weld can be gray and it's no problem at all. "
I have emphasized this many times. Hit the weld with a wire wheel. If it shines up, you're fine; It's just surface oxidation. If it stays grey, you've overheated it and affected the alloy.
His suggestion of the single point spot weld (no filler) is a great idea for determining that your gas coverage is leak-free and pure without doing an end-to-end leak test. I'm stunned this simple solution never occurred to me, and I'll be using it.
All those pretty colors on Instagram and Weldporn spoil everyone..lol
Markus is spot on, while color CAN be a good indicator, it is not a tell all as Steve has pointed out. I weld sanitary and it sometimes will have a duller color too it, pickles and polished up mirror finish so it is just fine.
The 16g will challenge you, it can get heat soaked quickly.
Markus, I did your test looks like I have an equipment or gas problem.
The photo is done at
45 amp
25 sec post flow
#6 cup (I tried it with a #8 gas lens and got similar results)
I have tried to find leaks here is what I have done
first tank gauge still shows almost the same pressure half an hour after tank is turned off so I assume line to welder solenoid is tight
Second with a extra quick connect I have for the argon to the welder I made up a short hose and a gauge. Shut off tank, tripped solenoid so gauge showed output pressure. After 20 minutes the gauge had remained at same pressure so I am guessing all is tight to the quick connect on the machine.
Torches I have two changing them makes no difference. I have visually inspected them everything looks good as far as I can see. Is there any better way to check the torches?
Thanks again for all your help
Mark
PS grey welds clean up with small hand wire brush and shine when buffed so I guess they are usable.
45 amp
25 sec post flow
Mark
- IMG_1138a.jpg (28.75 KiB) Viewed 1769 times
Yup you definitely have a gas leak somewhere.
So you tested the welder for leaks and it's OK. On both sides of the solenoid, if understood correctly.
If so then there is only two options. Your both torches leaks or you have a bad bottle of argon.
What you mean by checking visually? You need a tester or soap water to check system from leaks. Otherwise it is impossible to tell results.
Do these next:
1. Check the torch for leaks while argon is flowing in it. Take soap water and spray over all joints and connections and try to look if any bubbles appear... Torch end cap, insulator, torch connection to the welder are usually places where leaks can be found.
If you can't find any leak. Then perhaps there is a leak in the torch line itself, if so you need to repair it at the local shop. However before paying anything for repairs I recommend to try my second advise below.
2. Try another bottle of argon if possible. There is sometimes bottle that contains too much moisture, which causes color and bad welds.
PS
You are able to check the torch from leaks on a pressure tester bench. Welder repairs shop usually offers these kind of services. They simply hook the torch on the pressure bottle, just like you would to the welder and then they block the torch head with special block.
Do these next:
PS
-Markus-
Threads on the torch head are either 5/16-24 or 3/8-24 depending on what you are using. Block it and hit the peddle. If there is a leak the ball will float.
Soap bubble test as mentioned works well, the only thing I'd add is that it helps to apply suds with a sponge rather than a spray bottle.
-Sandow
-Sandow
-Charles Dickens
-Charles Dickens
I guess it the gas?
I took the torch apart, (end cap and all cup end fittings off) unplugged the lead from the welder (gas feed separate connection) plugged both sides of the torch head with my fingers. When I pressed the peddle the flow meter jumped up as it pressurized the lines then went to zero, so the quick connect , hose and head are gas tight.
I then reassembled and did the soapy water test. I got a few bubbles, the largest about the size of a pea after 10 seconds of gas flow. This would seem to be a very small percentage of the gas flow at 20 cfh. I then using good quality stretchy electrical tape, I taped the joint between the end cap and torch body and tried the spot test again no better.
Does this all sound like a good torch leak test? Can anyone add to what I should try?
Thanks
Mark
Thanks
Mark
Nothing like giving a new welder a 40 page list of things to confuse him even more.
Is it possible that you have a bad bottle of argon? Yes. Is it more likely that the problem is the tank vs something you are still doing wrong? Not really.
If you take the tank back to your supplier they'll probably swap it out for free if you tell them it is bad. If it isn't hard to do that, why not. At least you'll know one way or another.
Just to sanity check though... You are running pure argon not 75:25 right? Those salmon color spots were with an on time of like a second right? You aren't cranking the gas flow rate way up to shield better right?
-Sandow
Something to be said about just getting torch time and worrying about perfection later... Get so torch time on mild steel where the material is cheaper and it matters less if you have some oxygen in your shielding gas.exnailpounder wrote:You should try welding
-Sandow
-Charles Dickens
-Charles Dickens
the tank is labeled Argon. No sparks or splatter.
The last test may be a little high on the flow 20 cfh and a #6 nozzle.
My steel welds don't look that nice either.
May have a chance to get access to another tank just to check if it is the gas
If I can't, It's only an 80 cf tank, and as you all say I need the torch time so I plan to run it out
Thanks
Mark
Thanks
Mark
- Braehill
Mark,
Any leak is a bad leak and sometimes the small leaks cause big problems as they are the ones that draw atmosphere in instead of blowing Argon out.
Another thing that needs to be looked at is your collet, if they are twisted and swollen, they restrict flow through the torch head. The best cure for this is to pick up the CK wedge collets and call it a day, they last almost forever and can't twist.
An 80cf bottle is one of the most likely candidates for moisture. They are usually bumped up to pressure off another (bank of) cylinder without ever being evacuated under a vacuum to remove moisture. If you own the cylinder and they fill it while you wait, this is almost assuredly what's happening. Get an inline moisture filter from Harbor Freight or the like and put it in the low pressure side of your system. Better yet, get a cheap vacuum pump while you're there and draw your cylinder down to vacuum overnight before you take it to be re-filled.
All that being said, I'm with the camp that says "who cares if it's not shiny". I weld quite a bit of small diameter heavy walled stainless piping and I'm here to tell you that most of it isn't shiny by the 3rd pass. Even if the weld itself is still shiny, the HAZ is definitely not. Did I overheat the pipe an inch on either side of the weld? Probably not, but it has reached a critical temperature in which it can oxidize without gas coverage. Shiny welds are achievable, but they come at a cost that most people in industry wouldn't be willing to pay. There are millions of dull stainless welds holding all manner things together all over the planet. Brush it and move on to the next weld.
Just my opinion, but if you're going for shiny, you're going to need a lot bigger Argon cylinder. It's all about gas coverage and get moving.
mpete53 wrote:My weld polish up good enough for my needs so as long as strong and stainless.
So I guess its time to just keep welding and get better if not as shiny as I would like, welds.
Thanks
Mark
Yup,but don't forget what you have learned in this thread. Welding with contaminated gas is relevant to welding with blunt tungsten. In worst case arc wanders and no matter what you do your welds look completely awful.
Change the bottle when the time comes and check if anything chances. Also fix those leaks when you have enough spare time. After all you can't improve your skills very far if machines aren't working properly.
-Markus-
I just started welding Stainless today, whatcha think
In all seriousness this I welded with my Jumbo CK gas saver (1-1/8"), 1/16" tung, 60amps 2.5pps 50%/50%, travel speed is fairly quick, full penetration with a back purge. Your doing fine, lots of good guys and experience on this site that will help point you in the right direction. Practice, Practice and more practice
- brushed...
- pipe2.jpg (26.94 KiB) Viewed 1811 times
- just welded 316L
- pipe.jpg (57.73 KiB) Viewed 1811 times
update
I am getting better. I still can't get the hang of the higher amperage welds you all talk about so I tried lower amps and a .040 tungsten and it seems to work for me'. I well keep trying those higher amp om practice plates though.
Plate weld: 16 gauge 304 stainless, no filler metal, 35 amps .040 tungsten #8 gas lens 20 cfh and resting on a 1/4 aluminum plate
Pole: about 14 gauge 316stainless with a internal stainless sleeve. Mostly without filler, 35 amps .040 tungsten #8 gas lens 20 cfh
brackets: 1/8 x7/8 unknown stainless pins welded no filler rest with 309. 45 amp 1/16 tungsten #8 gas lens 20 cfh. not yacht grade but cleans up enough for a work boat,
Thanks for your help
Mark
Mark
- IMG_1154s.jpg (55.57 KiB) Viewed 1783 times
- DLewis0289
By George I think you got it! Looks good, keep burning only way is up from here.
I got a new Lincoln auto darkening welding helmet. What a difference from my old harbor freight darkening. Also got the cheater lens.
I can now see the puddle and the arc clearly. Being able to see lets me get the arc much shorter creating much less heat.
Weld shown is thin walled tube to 10 gauge plate. The only post weld treatment was a light wire brushing.
Thanks again for the help
Mark
Mark
- IMG_1158.JPG (98.43 KiB) Viewed 1757 times
