Do you think there would be a good way to mount a momentary switch to or inside the body? CK doesn't offer that control with the addition of the momentary switch.
On the inside, there isn't much space left over. I have a momentary switch wired up separately on it's own 2-wire cable. I ordered the connector from HTP with the schematic, so I have that readily available as well.
You could always make your own with some thin copper contacts, or a single key from a keyboard, if you're creative enough.
Link? I didn't know the rotary track one came in different sizes.Poland308 wrote:I'm going to get the thermal arc version and add the two wire switch as well. Did you get the CK controler that has the smaller body or the bigger one?
dirtmidget33
- dirtmidget33
@RamboBaby since this thread got way off, have you started welding on transmission yet. Let us know if you encounter problems. Don't be afraid to grind off some of your first passes when You start the build up. If you think you have porosity. It typically happens in the first pass on the cast. Just crap in cast or contamination causes it , don't always get it but better to get rid of it early on. You can get stud counter sunk using a just a drill and dremel if need be, it just takes patients and careful control with tools. Done some crazy reshaping on some of the cases instead of sending it to machine shop.
The guy finally brought the machine over tonight. Was supposed to have brought it several days ago. None of the welding supply stores carry 4943 so I'm just gonna use 4043. Heck, none of em have ever even heard of 4943 so I had to look it up and show it to one of the shops.
Gonna get the thing cleaned up in the morning. Gonna preheat with an oxy/propane rig that the guy brought just for that purpose.
I'll let you guys know how it goes and post photos.
I also let him know that everyone recommended not reataching the ear and just building it up. He's good with that. Getting the hole back in it is gonna be his problem.
Edit:
You can see how filthy it is:
Edit:
- tmp_15623-20160724_0040421680690721.jpg (47.19 KiB) Viewed 1501 times
Raymond
Everlast PowerTIG 255EXT
Unless I need SMAW rods, I don't bother with LWS's. With Google at your fingertips, you can find anything. I get 4943 from Baker's Gas & Supplies for $55 a 10lb box. Cost the same as 10lbs of 4043. Shipped for free. You just have to email and ask about it, or use their online-chat service to get them to send you a quote. You have to remember that most salespeople at the counter at LWS's are not welders, they're sales people there to help assist with sales, but around here most don't know squat about welding. Don't get me wrong, I'm sure there are many very knowledgeable salespeople with working knowledge of various welding processes out there, but those are few and far between from what I've seen and read about, and are the exception and not the norm.
I had already come to that same conclusion myself. Good with charts and computers but don't know jack about welding processes and materials. But I don't have a credit card or even a debit card to order things online.Oscar wrote:Unless I need SMAW rods, I don't bother with LWS's. With Google at your fingertips, you can find anything. I get 4943 from Baker's Gas & Supplies for $55 a 10lb box. Cost the same as 10lbs of 4043. Shipped for free. You just have to email and ask about it, or use their online-chat service to get them to send you a quote. You have to remember that most salespeople at the counter at LWS's are not welders, they're sales people there to help assist with sales, but around here most don't know squat about welding. Don't get me wrong, I'm sure there are many very knowledgeable salespeople with working knowledge of various welding processes out there, but those are few and far between from what I've seen and read about, and are the exception and not the norm.
Job is finished. I'm gonna let him take a bastard file to it to finish slicking it off (I can't find one around here).
He requested that I reinforce the top of the ear so I gave him and extra 1/4" or so. Looking at the first photo and the last photo you can see how much I added. If it causes interference then I'll let him deal with it. He's a mechanic so that shouldn't be a problem.
Started out welding with 140 amps. That ear may be thick but that case is not. Didn't really have a problem with the case drawing my heat away. No preheat was used other than a few passes with the torch to get it warm and toasty. Halfway through I stopped for a minute and had to crank it up to 170 amps in order to continue. Same toward the end of welding and I needed to crank it up to 200 amps for the final passes.
Advanced pulse is NO GOOD FOR CASTINGS! It just makes a mess of things.
You were right dirtmidget.....this thing welded pretty nice.
- Cut out the rest of the bolt hole for easr of welding. This thing was still an extreme pain in the butt.
- tmp_370-20160724_114947-864512749.jpg (48.89 KiB) Viewed 1469 times
- Boiled the trash out with 125 amps.
- tmp_370-20160724_1204101828056698.jpg (39.2 KiB) Viewed 1469 times
- Cleaned with stainless brush.
- tmp_370-20160724_1207141766246673.jpg (35.37 KiB) Viewed 1469 times
- Building it up.
- tmp_370-20160724_133052-1682148703.jpg (38.55 KiB) Viewed 1469 times
- Filling in some voids.
- tmp_370-20160724_143032446525239.jpg (39.75 KiB) Viewed 1469 times
- Slicked off.
- tmp_370-20160724_1505591159687406.jpg (32.08 KiB) Viewed 1469 times
- tmp_370-20160724_150613605109235.jpg (33.55 KiB) Viewed 1469 times
- tmp_370-20160724_1506181680690721.jpg (40.68 KiB) Viewed 1469 times
Raymond
dirtmidget33
- dirtmidget33
Glad it worked out for you. Yeah the Polaris castings are pretty nice to weld on. I don't hardly ever use pulse functions on my machine. If I do use it, it's typically on stainless steel.
I totally discounted the validity of pulse settings on my machine until Rick_H showed me how to use them on stainless. That stuff comes out better than a robotic weld if you know how to use it correctly.
Thanks for the help brother!
Raymond
Nice repair work Ray! I know it sucks to have to rebuild an ear like that but it would have never held if you had only grooved out the crack and welded it. I always err on the side of caution on stuff like that. Not because it was a critical weld but because I don't want anyone coming back and bitching that it cracked off again.
dirtmidget33
- dirtmidget33
Well if the welding doesn't work out you got practice to perform in a different field of workRamboBaby wrote:The part that sucked was having to bend over and contort to try and get it done. Made me feel like a female porn star.
michellemacdroff
- michellemacdroff
