widowmaker
    Wed Aug 31, 2016 1:02 pm
Wondering about cost difference of the two. Given 2 same size cylinders, both filled to capacity with each, will CO2 cost much less? Also will either one give you more welding mileage given similar settings ? Thanks
hey_allen
    Thu Mar 05, 2015 6:09 pm
    SW Oklahoma
I'm not a master of welding, but from the physics side of it, an equal physical size bottle of CO2 will have far more gas in it than a CO2/Argon bottle, since CO2 is stored as a liquid.
Doing a quick search turned up information from Air Liquide claiming a 1:845 expansion from liquid to gas.
That said, I haven't welded with it, but heard that it is much more prone to spatter and that it tends to burn hotter, causing a deeper weld puddle.
-Josh
Greasy fingered tinkerer.
soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Sparks, NV
hey_allen wrote:I'm not a master of welding, but from the physics side of it, an equal physical size bottle of CO2 will have far more gas in it than a CO2/Argon bottle, since CO2 is stored as a liquid.
Inductance control will help control spatter.
soutthpaw
    Sparks, NV
    Tue Jul 19, 2016 6:52 am
I run straight co2 at home. 20# steel cylinder (beverage carbonation size)$60-80 for tank and $10 fill. lasts about me about 5# of .035 wire @25 cfh. C25 is $30-40 for M size bottle fill (125 cubic foot) tank is $210. I have used both gasses extensively over the past couple decades and I think the notion of spatter is greatly over exaggerated. As Jody describes in some of his videos, the voltage range that co2 runs well in is narrower than c25 so it may be easier to have your machine set up poorly. Co2 is generally considered to produce better penetration.
I think co2 is liquid vs c25 mix is gas so that might make it difficult to compare volumetrically.
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
Jim FLinchbaugh
    Thu Sep 01, 2016 11:56 pm
    Kalispell Montana
[quote="maker of things" As Jody describes in some of his videos, the voltage range that co2 runs well in is narrower than c25 so it may be easier to have your machine set up poorly.
[/quote]
I've had my MIG for almost 20 years, and was pleased with my hobby welding skills I learned myself
until I saw Jody's videos mentioned above. Turns out I had NO idea how to set up my welder I "knew" how to use.
His methods eliminated 85% of the spatter I used to get using straight Co2
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Another consideration: because it runs hotter it doesn't work well on thinner materials such as auto body panels.
Also, if you already have an argon-co2 flowmeter, you'll need an adapter to fit it to a co2 cylinder. But they're easy to find and not expensive.
Dave
aka "RTFM"
you should check out the welding gas costs thread. It has pricing from all over the country, and world :D
Solidcore
    Wed Aug 24, 2016 1:38 pm
Co2 will last the longest. It's burns a bit hotter and a bit more splatter. C25 is nice and makes smoother welds.
