Respectfully, I would have to disagree with your cleaning action statement.cj737 wrote:When you MIG aluminum, you will get smut because you're welding with DC and have no cleaning action. To minimize smut, crank up the CFH (pure argon) and use a push angle. As mentioned, if you're welding outdoors, be mindful of the breeze as a little cause a lot of problems.
You also look cold on the welds, so crank up the volts and slow your travel a tad. A gentle brushing afterwards with a stainless brush cleans those welds right up (but they'd better be good welds else your mistakes show )
Welding with DC+ is the cleaning polarity. DC- is the penetration.
These are the 2 that get adjusted on tig machines with adjustable balance.
On mig aluminum, you only get the DC+
Completely agree that the settings are off.
Could be wrong polarity or just not adjusted correctly into spray?
For the OP, here is a short video of what spray arc looks like (the arc itself looks very similar for aluminum and steel).
Make sure the sound is on so you can hear what it sounds like.
Also, make a weld, post all related settings that made it. This makes it easier to help.
https://www.youtube.com/watch?v=IHkbh0oKv_g
- Farmwelding
What did I do this time.Poland308 wrote:Easy Farmer!
Sharn schimke
- Sharn schimke
YesPeteM wrote:Is your polarity correct?
I'm not awesome with aluminum, but I've never seen it do that.
Sharn schimke
- Sharn schimke
Thanks!MinnesotaDave wrote:Respectfully, I would have to disagree with your cleaning action statement.cj737 wrote:When you MIG aluminum, you will get smut because you're welding with DC and have no cleaning action. To minimize smut, crank up the CFH (pure argon) and use a push angle. As mentioned, if you're welding outdoors, be mindful of the breeze as a little cause a lot of problems.
Sharn schimke
- Sharn schimke
No all insideAndersK wrote:Are you welding outdoors?
Just a little draft can blow your shielding away.
Sharn schimke
- Sharn schimke
Sharn schimke
- Sharn schimke
Sorry but you wrong !!!! Aluminium is 100% argon.exnailpounder wrote:Your shielding gas is wrong. You need 75% Argon and 25% CO2 or straight CO2.
Sharn schimke
- Sharn schimke
It has been changed twice at least. And now from a different supplier with no connect to each other.Artie F. Emm wrote:Farmwelding wrote:He's welding aluminum right. If he is then definitely 100% argon. Aluminum doesn't like carbon dioxide.exnailpounder wrote:Your shielding gas is wrong. You need 75% Argon and 25% CO2 or straight CO2.
We may be hitting and missing the mark simultaneously. Sharn got sooty welds at home, moved the machine offsite and got good welds, then sooty welds back at home. The gas bottle at home may be mislabeled or contaminated, even though it is marked 100% argon. Sharn, is the bottle at home new, or recently exchanged? Have you made good welds with this gas?
Is the plug you plug the welder into good and tight? And is the voltage correct? I.e. Do you have a bad plug internally at the wall. Is there any thing else you took apart to transfer the welder to the other location that may have gotten reassembled one way when you were there and a different way when you got home?
Sharn schimke
- Sharn schimke
No all the same assembly. All the wiring in the wall is new and good so is the plug on the machine.Poland308 wrote:Is the plug you plug the welder into good and tight? And is the voltage correct? I.e. Do you have a bad plug internally at the wall. Is there any thing else you took apart to transfer the welder to the other location that may have gotten reassembled one way when you were there and a different way when you got home?
Can you take a picture of the front of your weld machine? So we can see where your dials and or switches are set? Is this a 3 phase or single phase powered machine?
Artie F. Emm
- Artie F. Emm
Back to the gas for a minute: you said the bottle has been changed, got it.
Have you made good welds with the gas from the current bottle?
Dave
aka "RTFM"
aka "RTFM"
- 5th Street Fab
To me it looks like bad gun angle. Point your gun at a 15 to 20 degree Pushing angle. When I started I found I needed even more of an angle then I thought. Try it.
Remember with aluminum it's push only. When you pull the gun it'll look like your picture.
Sharn schimke
- Sharn schimke
No! No better!Artie F. Emm wrote:Back to the gas for a minute: you said the bottle has been changed, got it.
Artie F. Emm
- Artie F. Emm
- poor quality welds at home
- good quality welds away from home (at the trade school)
- never able to achieve good welds using gas from the bottle at home
Contaminated gas at home? Mis-labeled bottle contains other than pure argon?
Dave
aka "RTFM"
aka "RTFM"
