It is currently Sat Feb 24, 2018 6:03 pm Advanced search
Need some guidance on MIG settings for Aluminum
Re: Need some guidance on MIG settings for Aluminum
Postby AKmud » Thu Apr 20, 2017 10:52 am
With that small machine, I'd try some pre-heat to give it a little help.
AKmud
Postby Olivero » Thu Apr 20, 2017 1:44 pm
Okay, I mean these plates are 48" X 76" and the seams are the 76" seams, multiple ones so its not going to be all that easy to pre-heat, I will be Tigging in there which will definetley warm up the plates :lol:
Olivero
Postby AKmud » Thu Apr 20, 2017 6:27 pm
You can still pre-heat around the joint. Any heat you can add to the aluminum in the area of the weld will help. It will be less area for the welder to heat up so your starts won't be so cold.
AKmud
Previous
