Re: Need some guidance on MIG settings for Aluminum
Posted: Thu Apr 20, 2017 10:52 am
by AKmud
With that small machine, I'd try some pre-heat to give it a little help.
Posted: Thu Apr 20, 2017 1:44 pm
by Olivero
Okay, I mean these plates are 48" X 76" and the seams are the 76" seams, multiple ones so its not going to be all that easy to pre-heat, I will be Tigging in there which will definetley warm up the plates
Posted: Thu Apr 20, 2017 6:27 pm
by AKmud
You can still pre-heat around the joint. Any heat you can add to the aluminum in the area of the weld will help. It will be less area for the welder to heat up so your starts won't be so cold.
