    Thu Dec 25, 2014 9:25 am
    near Chicago
Chips O'Toole wrote:You must know the answer to this question, then. Am I supposed to be getting all that brown residue?
Yes and no.
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
Yes and no.
Why not explain it Jeff. Why yes and why no...
    near Chicago
Yes and no.
I can't explain it because I have a bad hangover...what day is this? :lol:
    Wisconsin
A hangover and you are up at 6:00 and on the forum? wow this man needs a beer or something. Oh and its Monday...but for a second I thought it was Wednesday and then I thought Tuesday and I dont have a hangover so...
    Sun Oct 27, 2013 10:57 pm
Yes and no.
Agreed :D
    Thu Dec 01, 2016 12:30 pm
    FL
Given the choices, I choose "yes."
Chips O'Toole wrote:Given the choices, I choose "yes."
Sorry man, you don't get a vote because you're not supposed to be getting all that brown stuff :shock: :D
    near Chicago
Right! A little smoke is normal sometimes but not the whole weld. I looked closer at the pic and you even have soot on the table :shock:. Gas trouble somehow/somewhere. Is your nozzle and contact tip full of spatter? It builds up really quickly if you don't use nozzle gel and will cut your gas flow down considerably.
If the bugs were coming in was there a breeze blowing around as well?
    FL
Before I did that weld, I took the nozzle apart and cleaned a ton of brown crap out of it.
    near Chicago
Chips O'Toole wrote:Before I did that weld, I took the nozzle apart and cleaned a ton of brown crap out of it.
No telling then. You need to look for gas problems. You're getting some shielding otherwise your weld would be porous but you must be drawing in air or something. You're using 75/25?(C25)
    FL
I believe I loosened the cable connection when I changed the spool from stainless to steel. That would explain why I lost gas. But I tightened it up and cleaned the nozzle before making the long weld in the photo, which was surrounded by brown dust.
It's C25.
I don't suppose wire lube would make that stuff? I have two felt things on the feed mechanism, lubing the wire.
I have a couple of CO2 tanks from my brewing days sitting around. I could try a pure CO2 weld and see what happens.
I'm really happy about the weld, though. It's a big improvement over recent efforts, and there's a much nicer one on the other side of that piece of scrap.
Yes that lube can do stuff like that. I used to use the pads but just dry.
Poland308 wrote:Yes that lube can do stuff like that. I used to use the pads but just dry.
Agreed. I've used the lube only rarely, and it only takes a couple drops. We had one guy at work who would saturate the pad like he was greasing the wire rope on a crane, and couldn't understand why his welds were crappy. I now never use the lube. It's less hassle to replace the liner occasionally.
    near Chicago
When I dip my nozzle in the gel, my machine doesn't want to light up and it soots a little but not much and the welds are fine so I doubt oily felt is causing your problem...you have a gas problem. I put some big dessicant packs I got from a shipment inside the chassis where my wire spool is...seems to help during the humid weather and I threw my felts in the burner. Keep your wire dry and the lid closed and you won't have dirty wire...felt cleaners...IMO..gimmick. Like I said earlier...you're getting some decent gas coverage because your weld isn't porous and all slagged up but IMO you're not getting enough CFH or too much and swirling or you have bad gas.
    near Chicago
There's about a thousand "lube" jokes I could make right now...but I won't...maybe somebody else will :lol:
    FL
I ran a few more welds, and they look great. There is still some brown mess, but it's all on the far side of the weld, where the gas blows it. I'll keep fiddling with it and trying to make sure the gas is okay, but the welds look perfect. It does sound a little bit like making popcorn, however.
The wire is ancient. It's shiny, but I can't swear it's perfect. I'm using the spool up for practice.
I can't believe how much TIG has improved my MIG skills. I see better, and my right hand is much steadier now.
My big problem now is that I've been welding my practice scrap together, and the resulting "sculpture" is getting pretty big.
    near Chicago
Let us know.
