Yeah. Typically the OCV is (open circuit voltage) when the machine is on but not welding. Then when the circuit closes with the trigger depressed it switches to operating voltage with current and the welding begins.Sacman wrote:Out of curiosity, because I don't know lol. Do you think that it will change under a load?PeteM wrote:That seems very high for operating voltage. Probably normal for OCV though.
It should not change more than millivolts, since you have a "constant voltage" source for MIG. However, these numbers are very high for the machine you're using. You're sure the voltmeter was set for DC?Sacman wrote:Out of curiosity, because I don't know lol. Do you think that it will change under a load?PeteM wrote:That seems very high for operating voltage. Probably normal for OCV though.
You "may" have to have someone record actual welding voltage, but if this varies from OCV that much, the voltage will change a lot with wire speed, meaning it's nowhere close to being a "constant voltage" source.
How the pictures looked it was high voltage is made entirely be correct. And if it's the transformer based machine could have an internal short across some of the winding causing the high voltage.
Not really. I have a similar machine that reads similarly. When no welding is being done, the circuit is open, therefore the term OCV, or open circuit voltage.
32 volt max OCV is very typical for that line machines. Millermatics are typically around 30 also.
It's ChuckE, but useful enough-
https://www.youtube.com/watch?v=K_zBP-psFUk
Sacman
- Sacman
Hey Steve, here is the meter I used. I brought it for a repair on a clothes dryer and didn't wanna spend a whole lot of money on it considering I was hardly ever going to use it. It got the job done lol. I left it on the setting I used. I'm not very savvy with sort of stuff. I'll give it another go but with actual use and report back, Thanks Chris.Otto Nobedder wrote:It should not change more than millivolts, since you have a "constant voltage" source for MIG. However, these numbers are very high for the machine you're using. You're sure the voltmeter was set for DC?Sacman wrote:Out of curiosity, because I don't know lol. Do you think that it will change under a load?PeteM wrote:That seems very high for operating voltage. Probably normal for OCV though.
Sacman
- Sacman
Here is my machine that I'm using. According the website they made several different models "weld pak 100" hd and plus. They all seem to be the same,just wondering is all. Thanks guys for all your useful help and knowledge it's appreciated.
sacman, set voltage to B. Then take a gun in one hand, another hand shall grab the wire speed control knob. Grab piece of scrap metal, thick one preferred. Begin to weld one handed and adjust your wire speed with another hand. If it is too slow you gonna see slow large droplets of metal falling, if too fast, your wire will stuck in the puddle and spark a lot as an arc can not melt it so fast. Find those two extreme points, too slow and too fast and turn your wire speed knob in the middle between those two - that`s your welding current. Nice buzzing low spatter euphoria. If you need more energy, move to C and repeat the story.
Ooops, flux core, but, should work. Just drag not pull your welds. And move your gun in C pattern.
Sacman
- Sacman
cherwolf wrote:sacman, set voltage to B. Then take a gun in one hand, another hand shall grab the wire speed control knob. Grab piece of scrap metal, thick one preferred. Begin to weld one handed and adjust your wire speed with another hand. If it is too slow you gonna see slow large droplets of metal falling, if too fast, your wire will stuck in the puddle and spark a lot as an arc can not melt it so fast. Find those two extreme points, too slow and too fast and turn your wire speed knob in the middle between those two - that`s your welding current. Nice buzzing low spatter euphoria. If you need more energy, move to C and repeat the story.
10-4 will do, thanks for the advice.
Sacman
- Sacman
yeah I brought a new auto dimming helmet and was messing settings in the beginning of the night those pics where taken. Thanks for the friendly advice.Oscar wrote:Get a better helmet. I don't think you can see the puddle, or the "line" that you're supposed to be following from the weld joint.
I stand corrected. I pulled out the manual for the Millermatic 252 today, and looked at the volt/amp curves, and OCV does not match setpoint voltage below about 50A, or basically while not welding.
Our ancient Lincoln CV305 transformer machine does seem to match OCV to the setpoint whether it's loaded or not.
My bad...
My bad...
Sacman
- Sacman
Ok so your saying my machine is a transformer machine? I haven't had a chance to use the volt meter while welding yet. Should I still? Sounds like I don't. lol I think. I read the manual I don't remember seeing anything specific like that in there. I have a lot to learn, thanks.Otto Nobedder wrote:I stand corrected. I pulled out the manual for the Millermatic 252 today, and looked at the volt/amp curves, and OCV does not match setpoint voltage below about 50A, or basically while not welding.
My bad...
