[quote="Antorcha"]Take a deep breath. Let the smoke out slow.
#1. Forget using a 110 welder on 3/8 steel. Period.
#2. Forget using a 110 welder on 3/8 steel. Period.
#3. Go get some 1/8 steel.Leave your machine maxed out. Go weld some 1/8 steel.
Penetrated purty good didnit ?
Ever took a look inside the door on that machine Aussie ? See anything about 3/8 steel ?
But,,,,even though he won't be able to make a 3/8 bead capable of welding 3/8 in a single pass. He should be just fine welding a bead big enough for 1/8 steel on a 3/8 plate. It won't just stop working because the plates too thick. If he's on good clean steel and gets the machine dialed in then the resulting weld will have good wet in on the edges. Regardless of how thick the base plate is!
Lcgixxer87
- Lcgixxer87
I'm new to mig myself, just done it a few days breaking from my vertical stick. I can get good penetration and a good form up to for the most part on my laps but am having trouble with the lower end piling a little and not penetrating. I think this gun angle tip will be helpful. I do a good tilt in stick, perhaps I need to do a more straight on approach with the mig gunPeteM wrote:Also, how is your gun angle? It shouldn't be more than a few degrees off of 90, but a lot of new to mig guys will end up tilting the gun way over to kind of see what is going on. That just stacks the metal upon itself with virtually no penetration/fusion. This also messes up the contact tip to work distance.
Lcgixxer87
- Lcgixxer87
I'm new to mig myself, just done it a few days breaking from my vertical stick. I can get good penetration, pretty beads, and a good form up top for the most part on my laps but am having trouble with the lower end of the bead piling a little. I think this gun angle tip will be helpful. I do a good tilt in stick, perhaps I need to do a more straight on approach with the mig gun
