    Wed Jan 22, 2014 12:00 am
    Connecticut
I am welding up some .120 wall 2x2 mild steel box tubing. For a change and as a learning experience, I decided to ignore the door chart and try the method Jody outlines in this video: https://www.youtube.com/watch?v=sZuq4XQTHVs
I am running a Hobart Handler 190, 0.030 ER70S6 Lincoln Superarc L56 wire, C25 gas, and I set the wire speed to 240 inches per minute (24 inches of wire in 6 seconds, I timed it). I could not find a voltage setting that would work. The wire was popping and sputtering and hissing.
I took apart the gun, blew out the liner, reinstalled the gun and tightened down the drive roller to make sure I wasn't having wire feed issues. Re-measured the wire feed speed again, and still no luck. Now if I turn up the wire feed speed to somewhere around 450 inches a minute, I had no problem dialing it in, on either tap 4 or tap 5. Coincidentally this is the setting the door chart recommends.
So what am I doing wrong? why does this work for Jody with his 210MVP, but not on my 190? the machines are not all that different.
Multimatic 255
    Connecticut
nothing??
Multimatic 255
PeteM
    Sat Dec 03, 2016 11:28 am
    Pittsburgh
Just speculation, and I didn't want to stick my neck out too far, but- The spec sheet for L-56 specifies co2 for the lower speeds, and only get into mixed gasses at higher deposition rates.
So maybe its a property of the wire? I've run L-56 a ton, but always at lower rates and always with co2. Never had problems as you described, but it also never occurred to me that there would be a significant difference either way.
