It is currently Sun Feb 25, 2018 9:35 pm Advanced search
Wire size 150A Mig
Wire size 150A Mig
Postby Brettm357 » Fri Jun 16, 2017 11:20 pm
Newbie learning to Mig max steel thickness probably about 3mm 1/8 inch Mig spec sheet is 40 Amp Min 150A Max - should i be using 0.8 (.030) or 0.9 (.035) wire
Machine about 30 years old that i just brought Currently has 0.9 in it
Brettm357
Re: Wire size 150A Mig
Postby MinnesotaDave » Fri Jun 16, 2017 11:40 pm
.030" wire has a range roughly of 40-145 amps - it's a great wire for your size machine.
Airco 300 - Syncro 350
MinnesotaDave
Postby Brettm357 » Sat Jun 17, 2017 8:57 pm
Any disadvantage using the .035 up first
Brettm357
Postby MinnesotaDave » Sat Jun 17, 2017 10:07 pm
Not really, it's approximate range is 50-180 amps.
MinnesotaDave
