CountryB
    Sat Jun 10, 2017 2:52 pm
I'm planing to do some custom exhaust work. I have the Hobart Handler 140 (Mig).
I'm a beginner welder with Mig.
I want to weld a stainless steel "Catalytic Converter" to 3" steel (aluminized) exhaust pipe. The exhaust pipe is 14 GA.
Should I get Stainless Steel .023 wire (if so, do I get the ER308L, ER309L, ER316L wire, or something else), or do I just weld with the regular steel .023 wire I already have.
Or should I just use clamps? If welding SS to steel is hard to do.
The rest of the exahust work is all (aluminized) steel (typical exhaust pipe). Does that take any special precautions or just weld as any steel would be?
309 is intended for dissimilar metals, I've never used the mig version but I've tig and sticked lots of 309.
