eliotmay
    Tue Oct 25, 2011 6:56 am
    Brookfield wi
I have a northern mig 135 (my first welder), has always worked fine but lately it has been acting up, now It won't feed wire but it makes the normal loud click when I hit the button, but the rollers don't roll. Wire feeds manually fine. Any ideas?
Hobby welder
my equipment:
Miller diversion 165
Northern mig 135
Wish list: plasma cutter, miller mig, low rpm chop saw with metal blade, oxy/acet setup, six car garage, modine
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hi there,
If you can take the torch off the welder, bend a piece of mig wire into a U shape and put an end into the spots where the control pins of the torch go. This will tell you if the problem is with the torch. If, when the wire is touching both control pin sockets, the wire feeds and the gas comes out, you know the torch has a prob. If not the there is a prob in the machine. Hopefully just a fuse of something small.
Good Luck.
