KenO
    Sat Jun 19, 2021 8:21 pm
    Northern lower Michigan, Florida winter
New guy here. I just bought the new machine above, all is well, except I can't seem to find out how to purge the line without feeding wire. I read the manual, its probably in there somewhere, watched a bunch of youtubes also. There has got to be a way, and hope someone on here knows.
I want to try pulse by y-valving my argon and C25 together. Thanks, Ken
Miller Dialarc 250
Hobart 140
Miller legend 200 AEAD engine drive
HTP 220 MTS
Carl Spangler
    Mon Jul 05, 2021 1:20 pm
I just ordered this machine and your question got me digging through the manual.
There doesn't appear to be a dedicated purge button/command on the 220.
As a workaround, you could set the pre-flow to something like 10 sec to purge the line. Once this is initial purge is finished you would then set the pre-flow back to a normal setting.
KenO
I have been unlatching the pressure roller on the wire feed, hit the trigger, and let if flow to purge.
Miller Dialarc 250
Hobart 140
HTP 220 MTS
KenO wrote: Mon Jul 12, 2021 6:57 pm I have been unlatching the pressure roller on the wire feed, hit the trigger, and let if flow to purge.
That's what I do.
