nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
Hello,
I have Blue Demon 308 Flux core wire I'd like to use for a low tech decorative project.
It's 316 I want to weld.
Could this work?
Thanks!
For low tech decorative, yes.
nelson
    near philly
Thanks! The label says up to 308
Knowing a little about metallurgy, I'm not sure about the "up to 308". Would there be an alloy ingredient involved...
Filler wire is labeled with appropriate “structural code” ratings. What you are doing can safely be done with 304 candidly.
Ideally, you always use same or better grade wire when dealing with stainless. But for decorative, no sweat-
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
just keep in mind the weld will corrode before the rest of the piece does. that might be an issue in marine/beach environments.
