MadeinTexas1817
    Wed Oct 12, 2022 12:20 pm
The Company I work for is wanting to start a new weld procedure and they're wanting to use .045 Hardwire I've been struggling to get the voltage and wire spread dialed in, and help or suggestion would be greatly appreciated.
corn chip
    Wed Oct 05, 2022 10:20 pm
millers website has a calculator thing . tells you the ipm, volts and amps for a given material thickness and wire diam. i use it and it works well
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
What thickness steel are you welding? What is the orientation of the part? What settings have you actually tried on a specific part? (please don't say you've tried everything, because that doesn't help us help you, lol). How do you know it is not dialed in, as in, what are you seeing/measuring/detecting/observing that tell you 'something is not right'?
