elviswongg
    Sat Oct 03, 2009 9:13 pm
Hello
I have a mig, i wonder if it is possible to weld Stainless steel with it using Stailess steel flux only ,
cause i dont have argon,
I have to weld exhaust pipe
Thank you :)
brian
    Sat Oct 03, 2009 10:11 pm
Not sure about S.S. Self sheilding flux core, but if you don't mind the welds rusting you can use mild steel wire. It will hold just fine.
elviswongg
Ok Thank for the advice i though that steel wont held on SS , but i will try it , as it is a muffler pipe i dont mind about the lokk as long as the welding held the parts
:D
