Devildog2076
    Thu Feb 26, 2015 11:50 pm
Another simple question about aluminum mig welding--Can you use 4043 wire to weld 5 and 6 series aluminum? I have seen a 5 series wire but not a 6. Thanks for your help. :?:
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
I know for TIG welding I use 4043 on 6061 on a regular basis. It's actually the preferred filler metal. I also use 5356 on 6061 as well. I'm not sure on the 5xxx series of aluminum, I've never welded any to my knowledge, and if I did I would have used 4043.
Devildog2076
thanks so much.
