Hawk
    Tue Mar 10, 2015 1:05 pm
Hello, I'm stuggling with 4F welding position.
link to img: http://www.part.lt/img/218241d42a72a0a2 ... f26795.jpg (image appeared abnormally while in [IMG] tags.
This position are causing a problem, and ruins the working piece.
Waiting for some cool tips :)
jwright650
    Wed Dec 03, 2014 3:27 pm
The picture that you posted shows a 4mm fillet weld on the "other" side of the joint...opposite side than the arrow is pointing to.
John Wright
Hawk
just wondering how the pic appeared so huge here :?
Also, i don't get to weld in that position at all. Tried lowering volts, also feeding. Doesn't help. The weld just ''falls down''.
Probably i'm doing something fail (torch angle?) or something
Semantics of weld symbols aside, for that 4F weld you should be pushing, not dragging. Torch angle should be about 60* "up", and 15-25* "forward", rather than dragging your bead behind you. Work from the outside to the middle and push your puddle.
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Hawk,
What were your settings?
Hawk
Otto, thanks for explaining this.
Superiorwelding, that;s pretty hard to say, since those machines does not have amp/volts indicator.
