nitrox650
    Sat Oct 03, 2009 12:59 pm
i
javiajero
    Tue Nov 10, 2009 3:55 pm
hello, I'm not a pro welder, but I like to learn to weld mild steel and aluminum because I'm restoring an old 1970 Land Rover, I have a Lincoln 175HD pro pak, either may I use 100% Ar to weld mild steel and Aluminum without change bottle gas or what is the better gas 75/25 for mild steel?
Thanks for your advice
nitrox650
javiajero wrote:hello, I'm not a pro welder, but I like to learn to weld mild steel and aluminum because I'm restoring an old 1970 Land Rover, I have a Lincoln 175HD pro pak, either may I use 100% Ar to weld mild steel and Aluminum without change bottle gas or what is the better gas 75/25 for mild steel?
you are going to have to change gas argon or argon mix for aluminum and 75/25 for mild steel
javiajero
[/quote] you are going to have to change gas argon or argon mix for aluminum and 75/25 for mild steel[/quote]
Thanks I am going to follow your directions.
